Question about Lexmark X5150 All-In-One InkJet Printer
WHAT DOES ERROR CODE 0504 MEAN ON A X5150 LEXMARK PRINTER
  • 619 Answers
SOURCE: ERROR CODE 50C
you need to buy the "original ink" it connot detect by generic ink.
Posted on Dec 31, 2007
Avwrexit
  • 47 Answers
SOURCE: error code 50c
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.If this does not resolve the issue then try the next steps.
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Posted on May 29, 2008
  • 4 Answers
SOURCE: hardware error code 0502
You have to use oil (olive oil) or petroleum jelly and wipe, using a paper towel, the horizontal silver bar that the cartridge carriage rides across. The ink builds up on this, making it difficult for the carriage to slide across. This works for me every time, and you'll notice a lot of ink on your paper towel!
Posted on Jan 16, 2009
namzyanzy
  • 435 Answers
SOURCE: hardware error o504
It shows color cartridge is missing because either the cartridge is not well placed or it is not there.
When you try to run the Clean option from the Ink Cartridge menu, the following message may appear: Hardware Error 0504.
To resolve this issue:
  1. Take both cartridges out of the printer.
  2. Switch off the printer using the power button.
  3. Disconnect the power cable from the back of the Lexmark X5150.
  4. Leave the power cable disconnected for 30 seconds.
  5. Reconnect the power cable and switch the printer on again.
  6. Reinstall the cartridges. (Follow the instructions on the LCD screen or refer to the following document: How to Install the Cartridges in the Lexmark X5150)
Posted on Feb 14, 2009
stif_NEC
  • 441 Answers
SOURCE: MY Lexmark X5150 All-In-One InkJet Printer Problem
HI try this its from the lexmark web site
Hardware Error 0502 on LCD Display ID:ENUS16536
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
How to Perform the Hardware Test on the Lexmark X5150 ID:ENUS3744
Using the operator panel on the printer:
1. Press the Option button 10 times until Cartridges appears on the LED display.
2. Press the + button 4 times until Self test appears on the LED Display.
3. Press Select. The printer should print a sheet of paper with one black bar and one grey bar.
4. If the printer fails to print, remove both cartridges and try the test again. (It will feed the paper through and print a blank page.)
5. If the test works with no cartridges in the printer, run it again with one cartridge at a time installed.
Posted on May 06, 2009
Error code 0504
Problem Error: " Hardware Error 0504 " on the LCD Display Solution When you try to run the Clean option from the Ink Cartridge menu, the following message may appear: Hardware Error 0504.
  6. Reinstall the cartridges. (Follow the instructions on the LCD screen or refer to the following document: http://support.lexmark.com/index?page=techlibraryKB&linkSelected=node2^subnode0&channel=techlibrarykbchannels&locale=EN&userlocale=EN_UK
Sep 02, 2011 | Lexmark X5150 All-In-One InkJet Printer
What does 50C error mean for my lexmark x5150 mean? When I go to print that is the code that comes up.
Its a cartage error. Remove the two cartage's one at a time. when the error stops you have found the bad one.
Aug 31, 2011 | Lexmark Office Equipment & Supplies
Printing stops and gives error code
The error is caused by either the cartridges or the encoder strip. Here's a link to the Lexmark website to guide you on what to do. Just click on this link: http://bit.ly/affECc .
Mar 31, 2010 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-in-One Error: 50
"When the printer fuser fails it prompts many HP laser printers to display an ERROR CODE 50 service code" same could be said about the lexmark fuser malfunction
replacining a fuser can be expensive might be better to get another printer unless you have a special bond like me i find it hard to just throw away things that have gone bad
Feb 01, 2010 | Lexmark X5150 All-In-One InkJet Printer
Errir 50C
Try these solutions from Lexmark online support: (apparently one of your print cartridges has shorted)
Lexmark X5150 Error 50C
Jan 09, 2010 | Lexmark X5150 All-In-One InkJet Printer
Lexmark all in one error
hi deborah,
thanks for using fixya.
The error that you are getting as well as the solution to the error can be found in the device's manual. troubleshooting also includes illustrations on how to get things done.
here is the link from lexmark.
http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
hope this helps.
regards,
voodoo
May 16, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmarx X5150
see on this site. I had the same problem before 15 minutes and it helps :)
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
Feb 15, 2009 | Lexmark X5150 All-In-One InkJet Printer
Hardware error o504
Jan 11, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
64 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
