Question about Craftsman 22" Gas Hedge Trimmer
Fuel hoses rotten
Fuel line replacement
3 Suggested Answers
bbreton
  • 437 Answers
SOURCE: try to replace fuel line craftman weedwacker
You will need to get some TYGON fuel line. Match it up to the size of each fuel line, some of these trimmer use two different size lines, and remember which size went on which connection. You will want about a foot of each. Cut one end of each line at a 60 degree angle. With a pair of needle nose pliers, feed the angled end of the fuel line into the hole going into the tank and feed it into the tank untill you can see at the tank fill. You cut the angled end off and put your filter on the line. Pull it back until the filter lays at the bottom of the tank. Hook this line up to the supply side of carburetor. Take the other line and put it in the tank about 1" or 2"
then cut it off to fit on the carburetor. HTH
Good Day.
Posted on Nov 10, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Need to replace fuel lines that is rotten
Hi randy waldrop...
Here is the fuel routing for chain saws
Please rate me
Bud
Posted on Oct 05, 2012
My friends 1999 Buick century's leaking break fluid from the dead center of the fuel tank. line runs hub to hub. how could a leak spring up in such a guarded area? Splice it there or what?
only replace lines as any other repair is strictly illegal and dangerous
the leak can be from rusted steel pipes and fittings or failed /rotten rubber hoses
Apr 14, 2015 | 1999 Buick Century
HOW DO YOU REPLACE FUEL LINE?
common problem the hose can be bought from chain saw outlets and you thread it through holes and grommets in side of tank..
Aug 13, 2014 | Garden
Problems with the fuel pressure system on 98 mercury sable
I'm not sure what this guy has done and not saying anything bad about him. I just want to help and explain a litle about your fuel system. As far as the gas lines blowing, You have metal and rubber hoses and am guessing the rubber hoses are the ones that had a problem. The only reason the metal ones would go is rust or something hittting them and knocking a hole in them. Ruber hoses can get rotten and get a leak. Below are some pictures of the underside of the fuel tank and as you can see many of those lines are mounted and if some of those mounts were not disconnected is could have pulled on one of the rubber lines and ripped it. I'm guessing that's what happened and he may have just said they blew. Will get to a blown line in a second. By the way I have been working on cars for over 25 years and have forgotten to disconnect things and ripped lines myself....it happens. Now fuel lines "blowing", in my years of working on vehicles I have hardly come across this unless the car sat for a long time and the fuel system was clogged up but even in those cases they were old and rotten. The fuel pump should only constantly run when turning the engine over or while it is running. If the system were that clogged it wouldn't run there for no extra pressure would really build up. When you turn the key to just the on position the fuel relay turns on for a few seconds and then automatically shuts off. Therefore your not just building and building pressure. Now the fuel regulator is done by vacuum. If it were bad you would have less pressure. They do not clog and cause a build up of fuel pressure and if they did, there is a diaphram inside the regulator that would blow and develope a leak (vacuum wise) and again no or little pressure not more. Below is also a picture of the fuel regulator and on top of it you can see where the vacuum line attaches. I hope I was able to help you understand a bit and just didn't confuse you more. Hope this helps...
Feb 18, 2012 | 1998 Mercury Sable
I have a 2150 poulan chain saw and my fuel lines are rotten and came apart, now I don't know what line goes where can you help me? I want to replace all of them.
You should have three hoses, the hose from the fuel tank with the filter on the end goes to the main fuel inlet on the carb, this is closest to the pump cover on the carb ( alluminium cover held with one screw ) the other connector on the carb has a pipe to the shortest connector on the back of the primer ( suction side ) the longer connector on the back of the primer ( pressure side ) has a hose that returns to the fuel tank, so the primer pulls fuel from the carb, and dumps it back to the tank
Apr 01, 2011 | Poulan 14" Chainsaw
1973 dodge 318 truck starts and drives fine until 35-40 mph then dies
Sounds like a fuel supply problem. Does it pop through the carberator as it it is dying, like a lean back fire? If you drove it up a hill would it die before 35 or 40 mph? If the fuel demand excedes the fuel supply the engine will die, but would restart after cranking the engine for awhile. Possibly a plugged fuel filter, fuel line, rotten fuel hose, ( sucking air ) or tired fuel pump. Hope this helps.
Mar 15, 2011 | Dodge W150 Cars & Trucks
Try to replace fuel line craftman weedwacker 32cc/1.9c.u -trimmer-hose all rotten cant figure how to replace
Good Day.
Nov 10, 2009 | Craftsman 25cc Gas Line Trimmer
My fuel lines became rotten and i'm not sure how to reconnect the in-tank fuel lines and filter
A bit more time consuming and requires patience more than skill on this task.
First, only take off 1 of the fuel lines at a time. That way you can make sure you put the right hose on the right fitting.
Let's start with the line with the filter. Take the line off the carburetor. Cut a bit of it and go to a mower repair shop to get your new fuel line. Get about 2 feet. That's about double what you need, but will probably waste some in the process. When you get the new line, cut a sharp point at 1 end. Get a needle nose pliers and reach into your fuel tank and pull out the filter and the rest of the fuel line. Get a fairly fine wire, wrap it around the pointed end of the new fuel line. Snake the wire into the tank and out the small hole. This will help you pull the new hose into the tank and out the hole. This might take a bit of time. When you get the new hose out, square off the end and push it on the carb fitting. Cut the hose where it enters the tank and slip your fuel filter on and drop into the tank. 1 down and 1 to go.
Host #2 can be put into the tank the same as #1, or you can try to push it in from the top. May work with a little lubrication. Hook #2 up to the carb.
This should get you up and running.
Oct 25, 2009 | Craftsman 25cc Gas Line Trimmer
Blown or just need a new hose
You might welded up your trasmission with no fluid you probly had dry rotted transmission line
If fluid leaking you dont drive it you stop. You could add fluid after you find the rotten transmission line replace it ow that fun i done this before.
Find the rotten line ore leak fix it cross your fingers add right fluid level and see if goes in gear also use correct fluid for that car all car take diffferent fluids types
Jul 21, 2009 | 1995 Buick Regal
Primer pump rotten need replacement show parts page
The hoses run through a hole into the gas tank, they are fitted with a filter inside the tank. Drain the tank, and manipulate the hose end to where you can grab it throught he filler hole, Remove the filter, run new gas lines into the tank and through the filler hole to replace the filter, reattach to the carburator. The primer bulb should have 4 small screws attaching it to the carburator. Remove the screws, place in new primer bulb, and you should be back to trimming asap.
Jul 06, 2009 | Garden
Craftsman 22" Gas Hedge Trimmer Logo
76 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
