Searching for Circuit Diagram of Sansui sv20021c as certain resistors are blown nearby the tube yoke circuit and values are not clear as resitors heated up very much.
  • 10,865 Answers
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
Dec 28, 2015 | Sharp Televison & Video
CIRCUIT DIAGRAM FOR SANSUI MODEL SV21276G
Sansui Sv 21276G value of resistor R817 2K2 1/4 watt
Feb 25, 2013 | Sansui Televison & Video
Sounds could be heared upon switching on of the set but the screen has no raster (means total blackout as if the unit were off. a small red LED located @ the front panel continuously blinks just like the...
Since you said the the pictur tube is glowing, your EHT system is OK.
After selecting a channel if sound is alright the TV up to signal
detection is working OK.
The problem now could be in video amplifier circuits. Check the grid
voltages of the picture tube.
Or switch off TV, and check the resistance values of the resistors
connected to the picture tube pins. Replace the defective resistor.
Check after removing one end of the resitor as it will misguide you if in circuit.
Aug 23, 2010 | Televison & Video
35 inch Mitsibutchi TV model #CS-35201A, serial #502637, manufactured 1993 TV made a popping sound when turned on and now only visable object is a straight horizontal colored line in middle of screen....
Hello dan82810,
The picture tube or CRT is not the problem, and yes this set is fixable. What has happened is that the vertical deflection circuit has malfunctioned. More precisely the vertical coupling capacitor has malfunctioned (The pooping sound was the capacitor exploding).
Open up your TV (take the back off and unplug the set), and look for the damaged capacitor, it will look puffy or if it has exploded.
To fix this problem you will need the schematic diagram for the TV (can be found at www.servicemanuals.net). Then you will need a multimeter to measure the DC voltages on the vertical output circuit, and finally an oscilloscope to measure the waveforms at the vertical output circuit and the input to the vertical windings of the deflection yoke transformer.
Now what you should basically find is a sawtooth wave at 60Hz which is the drive for the yoke transformer. However since the coupling capacitor is bad you will have the wave at the output of the vertical output stage, but not at the input of the yoke transformer. Use the schematic to find the value of the capacitor that has malfunctioned.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 28, 2009 | Televison & Video
Magnavox 27" TV- Burned Capacitor
For a schematic diagram, contact Philips directly.
Oct 04, 2017 | Televison & Video
Samsung projection tv convergence problem
I was just working on replacing my stk's and was wondering if you could tell me what value the resistors are? Here is my previous post if you would like to see it. http://www.fixya.com/support/t191186-blue_out
Sep 12, 2007 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
