Question about Electrolux 30" Self-Cleaning Slide-In Double Oven Electric Convection Range - White
Elextrolux Range stuck in Demo Mode
I have a brand new Elextrolux convection/self cleaning/double oven Range which was the floor model. It seems to be stuck in demo mode and there is nothing in the manual that directs me how to get out of it. Can you help?
  • vjdale Jul 18, 2010
    problem solved - just hold down the light icon together with the upper timer for 10 seconds within 60 seconds of connecting power to the range. You must first set the clock. Presto it is out of demo mode.
  • Electrolux Master
  • 909 Answers
Phone agents and ask for workshops. Quote them the model and problem you have.
Posted on Jun 06, 2010
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
Tip
Electrolux Model EI30GF55GSE Self Cleaning Doesn't Work
When using the self cleaning feature, you may see the panel flash remove shelves then go off after a minute. The solution is that there is a bar in the back left of the oven that is connected to the self cleaning sensor. After sitting a few months it may get stuck. Try moving or flipping the bar back and forth a few times. you should hear the sensor clicking . Then try to clean the oven. It worked for me.
on Oct 16, 2011 | Electrolux 30" Self-Cleaning Freestanding...
Eecrolux combination wall oven / microwave is in demo mode model# ew30mc65jb
Good Morning Rolf, thanks for your post!
Based off the information you have provided your Electrolux wall oven/microwave combination is stuck in demo mode. The best way to remove demo mode from your wall oven/microwave combo is to hold the oven light button and the on/off keys at the same time and you should be able to toggle in and out of demo mode. Hopefully this is helpful. -Matt
Mar 09, 2015 | Electrolux 30" Built-In Double Electric...
Highest temperature during self clean mode?
different brands, different models, different temps. they al range from 900 degrees up to 1300 degrees.
Apr 06, 2014 | Thermador SC302T Electric Double Oven
When in self clean mode latch will not lock latch has been replaced what do you think is causing this
If you replaced the entire lock assembly and it still does not work, the control board was originally at fault.
I assume there is no latching action when you call for self clean?
Double check you installation before you go buy a new control board.
Also check wire harness connection from new latch assembly to oven control board.
Oct 23, 2013 | Electrolux 30" Self-Cleaning Slide-In...
Trying to set it to clean, but it keeps saying remove racks even though the racks are out.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 11, 2010 | Electrolux 30" Self-Cleaning Slide-In...
How to clean Maytag self cleaing oven that needs some extra cleaning
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
May 11, 2010 | Maytag Gemini 30" Self-Cleaning...
Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Jan 22, 2010 | KitchenAid KESC307 Electric Kitchen Range
Fridgidaire Wall Oven will not heat
1) If there is a reset on the electronic panel try that.
2) Set the temperature to 200 and see if works then.
3) Put a baking tin in the oven with a piece of meat in it.
4) Uninstall the Wall Oven and take the back off and check the wiring for the elements and the convection fan.
Jan 13, 2018 | Frigidaire 30 in. Electric Gallery Series...
Electrolux 30" Self-Cleaning Slide-In Double Oven Electric Convection Range - White Logo
1,157 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
