Question about Maytag SAV2555A Top Load Washer
Maytag washer model #SAV2555AWW, Serial #14527322GL.....washer leaks....have had it back to dealer and they say it doesn't leak....they why do I have water underneath the washer when I do laundry? Have brought a friends washer in and used it and no water...have had all new plumbing done....can you help?
SOURCE: Maytag Ensignia Washer Leaks
I have the same problem. Just took mine apart here is where you can see how to get the front panel off. If I figure out the problem I'll post an update.
Panel opening:
http://www.applianceaid.com/atlantis.html
Posted on Feb 28, 2008
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Posted on Oct 10, 2008
hunter19_46m
  • 7482 Answers
SOURCE: How do you change the belt on Maytag washer model
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7.
Good luck, I hope this helps
Posted on Dec 01, 2009
  • 105 Answers
SOURCE: I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Posted on Feb 01, 2010
SOURCE: maytag atlantis washer got water leaking from
my problem was the "pump hose?
Posted on Feb 26, 2010
My maytag fridge leaks water the drip pan is dry and clean there is no visible water on it but there is a puddle that forms near the back on the floor the model of the fridge is MTF1954AR any ideas
Hi my name is Jordan and I am a representative of Maytag. I am sorry to learn of the issue you are having with your refrigerator. I have included a troubleshooting link to check out and see if this helps resolve the issue. If this doesn't help resolve your problem, please email me directly at Maytag.Digital@Maytag.com. Please include your full name, complete contact information, model and serial number off the appliance and the site we contacted you on. Thank you.
http://bit.ly/plDe33
Oct 10, 2011 | Refrigerators
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My maytag top load washer model #sav2555aww spins but not fast... I replaced the belt and that helped but still not like it did before.. Everything else works fine, any suggestions?
some of these machines have a timer conflict between rinse [ spin pulse ] and full spin at end of wash cycle the timer contacts remain in the pulse cycle the switching assembley may need replacing
Mar 05, 2011 | Maytag SAV2555A Top Load Washer
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My washer is leaking water from under the washer. what could the problem be
my washer is leaking water from under the washer
model #: MAH5500BWW SERIAL #10760798YY
Mar 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Model...SAV205DAWW leaking water at bottom
there could be 2 things that i know of
first one is that someone bended the door to much and the joint's are eather lose or out of place
the second thing is that the door sealing rubber is out of place, you need to putt it back to place
Dec 27, 2009 | Maytag SAV515DE Top Load Washer
Leak samsung front load washer
Hiya bcd1...what model number? see below info.. is yours one of these?
The front loading washing machines have been known to leak water onto the electrical connections to the machine's thermal sensor, which could cause an electrical short and ignite a circuit board, causing a fire.
The recall covers 250,000 Maytag washers and 20,000 Samsung front loaders.
Maytag machines affected have model numbers beginning with MAH9700 or MAH8700. The Samsung washers have model numbers beginning WF306BHW and WF316, although not all serial numbers are subject to the recall.
learn more detailed information about the recall by visiting Whirlpool...or Samsung's at www.samsung.com/washerrecall.
Hope you find useful!
Regards Faggly
Mar 19, 2008 | Washing Machines
Maytag washer is leaking
There are special tool designed to dissassemble this unit although it can be broken down without them if care is taken.
Having the model and serial number would help but be assured that the threading is standard (Rightie tighty, lefty loosy)
Maytag used different designs. Repair depends on the model/serial number. With this information I may be able to step you through the repair.
Knowing the age of your machine would be a plus in determining if repair is economically feasible.
Jan 02, 2008 | Maytag Legacy Series Top Load Washer
Maytag washer-leaking
look where you posted this in the range secton repost in the washer section thanks
Dec 17, 2006 | Tappan TGF320 Gas Kitchen Range
Maytag SAV2555A Top Load Washer Logo
289 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
