Question about Whirlpool Washing Machines
Showing 5d and making a buzzing sound and stop in middle of washing: whirlpool duet sport front load -ghw9150p
  • 5,081 Answers
5d is: It denotes suds lock (overdose of detergent dectected during the wash cycle).
Chances are you just put too much detergent in, or maybe the wrong detergent - make sure you're using the HE detergent.
These codes and more details are printed on the service technician diagnostic manual that is affixed to the inside of the washer's front panel.
Unplug your washer, and unscrew the three 1/4" socket screws at the bottom of the washer. The manual should be taped to the back of the panel, and the code and some recommended procedures will be right inside.
The error you have displayed is actually "SD", which is a SUDS detect error. This usually an indication of a restriction somewhere in the drainage system, a failed drain pump, you are using too much detergent, or you are using the wrong type of detergent. The following link explains the error in more detail and how to correct:
http://www.fixya.com/support/r3608687-sud_error
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code can be generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
COURTESY:jsrock - A senior expert of fixya....
Please donot forget to rate and accept my answer...
Posted on Jun 06, 2010
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
I have a whirlpool front load washer MOD number wfw8300sw04 ser Hlw2950160 it keeps stopping in the middle of the cycle it will not drain. We took it all part, clean the drain, did all the trouble shooting...
Hi Jamietigerbu, We sincerely regret to hear this. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Washer. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
May 30, 2017 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When the washer spin it has a load noise, it sounds like a plane is comming down. I have a duet sport whirlpool washer
the bearing probably went bad, thats the sound it makes, may even sound like a freight train at times.
Feb 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet 2 1/2 years old I t has started to make a loud buzzing hum sound (that sounds like old top loader mixing valve malfunction?) and has error code 5d what is this ?
Actually, your error code is "Sd" and indicates that the washer thinks that there are too many suds in the basket / drum.
Your buzzing sound is also likely to be the water inlet valves, common to top loaders as well, as the washer is adding additional water to rinse excessive suds out. Check your supply hoses for kinks, connections for scale buildup inside, as well as the screens on the inlet ports of the washer itself.
A kinked or restricted drain hose can also throw an Sd error code as well.
Jun 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front loader is making funny noises. It was
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Code 5d
its a water senser error code check for loose wire bottom front of outer tub ,i have never had a bad one "less soap plz"
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport
5d is: suds lock (overdose of detergent dectected during the wash cycle).
May 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
311 people viewed this question
Dan Webster
Dan Webster
Sal De
