Question about Refrigerators
I defrosted the freezer last week and the fridge will not get cold the light in the fridge is working and so is the freezer.
  • 54 Answers
There is nothing that work in the fridge it is just a box everything comes from the freezer. Check if the fan is running this is how the fridge gets its cold air. Check your freezer setting in your fridge. make sure it says warmer fridge. it a door that opens and closes.
Posted on Jun 06, 2010
The bottom freezer has exceesive frost, and is not cold enough. I tried to remove the frost, it will work for about a week afterwords. Help
Really when the fridge frost very excessively there is less cold.
You have to regularly set up defrost setting if your fridge has automatic defrost.
Or your fridge has manual defrost then defrost it twice a week.
To minimize excessive frost, set the temp control setting to just mid- position.
Good luck.
Jul 01, 2011 | Amana ARB8057CSL Bottom Freezer...
I have a Maytag 3 door ,freezer on the bottom, for the last 3 years every few weeks the fridge looses its coldness and the freezer is ice cold also it it always on temperature 1, so I have to unplug it...
Either, the defrost timmer has had it, or the freezer defrost element has failed, the element is the most common cause of this type of problem. You have ice build-up in the freezer cores because it cant defrost, all frostfree units rely on cold air from the freezer to blow into the fridge, if the freezer cores become blocked, air can not pass to the fridge side. I bet you, if you left the unit off for 2 days to defrost totally,,,,with the doors open...then plugged it back in, it would work like new for 2 weeks.
Timmer or defrost element needs to be replaced...do not fall for the trick that the fridge mech. has to take it away, you tell him that this is the problem and you will save yourself ALOT of cash.
Dont forget to vote for the solution...regards Russ
Mar 08, 2011 | Maytag Freezer MQC2257BE
The freezer appears to be working fine, however the fridge is not cold at all. For the last week it has been getting warmer and warmer.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2011 | GE Refrigerators
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Refrigerator and freezer not getting cold enough
If the problem just gradually started happening, it's possibly the defrost cycle that's not working right. Fridge doesn't defrost, the cooling system ices up, and the cold air can no longer travel through the fridge.
You can tell that's the problem if you fully defrost the fridge (turn it off for a day), then start it up again. If it works OK for a while, then does the same thing after a few weeks that's what it is. Either way, you need a repair person to fix it, or you need to defrost it regularly, but then what do you do with your food while you do that???
Nov 17, 2008 | Magic Chef CTF2125 Top Freezer...
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Refrigerators Logo
164 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
