Question about Canon Office Equipment & Supplies
My canon ir3100 problem it is error cod 0067-110
    Guru:
  • 389 Answers
It's the problem for service.. please call them
Posted on Jun 07, 2010
E000748-4041 ERROR CANON IR3100
Dear
The error occurs in accessing to the counter memory PCB.
Disconnect, clean and connect the counter memory PCB,
or replace it.
If problem persists replace the main controller PCB (Main).
Thanks.
Jul 07, 2014 | Canon imageRUNNER C3200 Copier
Tip
Error Code Canon iR2200 / iR2800 / iR3300 / IR3100
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Error Code iR2200 / iR2800 / iR3300 / IR3100
Error Code
Detail
Code
Error Name/Explanation of Error
E000
0000
The reading of the main thermistor does not reach 30°C 1 sec after the main power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
E001
0000
The main thermistor detects 250°C or higher.
0001
The main thermistor or the sub thermistor detects overheating (hardware circuit detection).
0002
The sub thermistor detects about 295°C or higher.
E002
0000
The temperature of the fixing film is as follows:
· has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
· has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
· has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
E003
0000
The main thermistor reading is lower than 140°C when paper is moved.
0001
Low fixing temperature detection after standby (by sub thermistor)
E007
0000
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
E010
0000
After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec.
E014
000
After the fixing motor drive signal is generated, the clock signal does not arrive within 1.3 sec.
E019
0000
The waste toner case is full of waste toner.
E032
0001
The DA unit connection is disconnected (after connection).
E051
0000
At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
on Mar 14, 2010 | Office Equipment & Supplies
Ir3100 error code e0070-0001 please help me is urgent show the solution with digram & show the sensor.
this is error for HP ITB sensor, which needs to be changed/cleaned.
For service manual, emma.servis@gmail.com
Jun 25, 2011 | Canon imageRUNNER C3170U Color Copier
Fax -L380 canon error cod Eooo
Fixing assy failure. Replace fixing assy.
May 18, 2010 | Canon FAX-L380 Plain Paper Laser
How can I replace the Canon IR3100CN Drum unit.
Hi, yes it is drum RELATED error, but before changeing the drum, clean the drum sensor. When you remove drum unit, inside of copier in drum unit place, from left side, uperr in the middle you have small sensor - Clean it!
Then try again.
If not tell me the exact error code eg. E 020 - 01A2 or?
It may be problem also in developing units.
Apr 26, 2010 | Canon iRC3100 Printer
How can i solve error code on my cannon ir3100 e602-001.
The wiring is faulty,short circuit or open circuit.The hard disk drive is faulty or the main controller board is faulty.For reset press: Copier-Display-Jam/Err.
Dec 02, 2009 | Canon Office Equipment & Supplies
Ir3100 : E00070-003 error code
canon ir 3100 error code E00070-003
Oct 23, 2009 | Canon imageRUNNER C3200 Copier
Canon IR3100 CN making grinding noise
hi..there...you may visit canon website at internet..chose product support/dowlnload----find your product here and finally you can get and download manual book as pdf for free....good luck..
Feb 03, 2009 | Canon imageRUNNER C3200 Color Printer
95 people viewed this question
old marine
old marine
