Question about Soyo SYTPT3727AB Television
I have soyo tv sytpt3727ab, i have sound but no picture
Soyo SYTPT3727AB Channels Turn By Themselves
It sounds that the main system control memory IC is faulty. Replace it with same type and number.32ee6750-5e09-4a11-8a1b-856db4a91606.jpgc33ec8ee-2b25-4306-9940-7e8f236a747b.jpg
The component will look like this, and will start with a number 24C***.
Jul 03, 2013 | Soyo SYTPT3727AB Television
Soyo tv code for shaw pvr remote
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV.
Jul 31, 2011 | Soyo SYTPT3727AB Television
I have a 27 inch lcd tv and I have no picture only sound. What could be the problem?
Now,turn on the tv get a flicker of a picture a few sec. only, than just have sound left?Yes,than the 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Jul 06, 2010 | Soyo SYTPT3727AB Television
Soyo DYLT032D - grey box in corner, no main picture or sound
I am having the same problem. Does anyone know the solution?
Oct 29, 2009 | Soyo DYLT032D 32 in. LCD Television
Tv only turns on, will go to soyo screen then black screen. when you can get the menu it only has symbles and no words can not turn off with out unplugging. never has a picture
Sounds like the Main Mother Board is the problem. Basically, it's the brain inside the TV. Controls and functions is that board's job.
Soyo parts are hard to come by. You can try running the number off the mother board on the internet and maybe a supplier will pop up.
Their Soyo.com web site isn't working. So, I'm thing they maybe out of business.
If you have some electronic experance and if your lucky, the heatsink on the chip processor is the problem.
Aug 05, 2009 | Soyo DYLT032D 32 in. LCD Television
My Soyo DYLT032 has power but no picture or sound
I HAVE FOUND 2 2200uf CAPS ON THE POWER SUPPLY BOARD THAT ARE PUFFED UP. CHANGING THEM USUALLY SOLVES THE PROBLEM. THERE'S ALSO A RESET BUTTON ON THE MAIN BOARD YOU MAY NEED TO RESET AFTER CHANGING THE CAPS.
May 30, 2009 | Soyo DYLT032C 32 in. LCD Television
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Dec 28, 2008 | Soyo DYLT032C 32 in. LCD Television
Soyo SYTPT3727AB Television Logo
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
