Question about FUJIFILM FinePix S100FD Digital Camera
Zoom error on fuji camera - FUJIFILM FinePix S100FD Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
SOURCE: fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Posted on Feb 19, 2008
SOURCE: Fuji FinePix S7000 Digital... Problem: Zoom Error
Fuji FinePix S7000 Didital Problem:Zoom Error
Posted on Oct 11, 2008
SOURCE: fuji fine pix z1 error
I had the same problem and finally had the time to look at it. I was reading some other posts, when I read try the telephone trick. Leave the camera closed and kinda slam it on a hard surface. I slid the shutter open and focused and it took a pic with no problem!!!
Posted on Mar 17, 2009
SOURCE: camera showing zoom error
Try the "reset" option in the menu on the camera...it fixed mine...I was having a focus problem in macro.
seax
Posted on Apr 13, 2009
  • 11967 Answers
SOURCE: Zoom Error with Fuij FinePix - looking for "telephone trick"
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 28, 2009
My f460 says zoom error
Here are some troubleshooting steps for Fuji "zoom errors".
Dec 09, 2012 | Fuji FinePix F460 Digital Camera
I try to turn of my camera but my zooming in thing doesnt go in and if you want to take pictures it says zoom error also when you try to turn it of the lenses that cover the camera doesnt cover.
Unfortunately, many cameras that fall prey to lens error (zoom errors on Fuji's) problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 03, 2011 | Fuji FinePix F440 Digital Camera
ZOOM ERROR Msg on screen..cant clear it
http://www.fujifilmusa.com/shared/bin/J10_E.pdf
P. 107 of the .pdf file (manual) says that if the zoom error occurs to turn the camera on and off, and then on, and if the error doesn't go away then contact Fuji support for service.
It's a camera malfunction or fault.
http://www.fujifilmusa.com/support/ServiceSupportRepair.do
The above link takes you to website for obtaining service for your fuji camera.
Jul 23, 2010 | Fuji FinePix J10 Digital Camera
I dropped my Fuji S5200 now it reads zoom error?
lens will not function normally,due to the mechnism fault,get it repaired by a camera tec.
Mar 09, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
Cannot erase ZOOM ERROR from my fuji finepix Z2
With the internally zooming lens on the Z2, there's no external access to any zoom mechanisms. A "zoom error" is not eraseable until the problem has been rectified. My guess is that the camera has taken some sort of impact, which often dislodges the track in which the lens travels. Not much you can do, yourself, other than a few well-placed "taps" to realign things. Next step is to have it serviced by Fuji, but given the age of the camera, it's likely not cost effective, sorry to say.
Feb 25, 2009 | Fuji Finepix Z20fd Digital Camera
Zoom on fuji f650 stuck
Hi Sandra, Try power reset for your camera. Turn the camera on, and without turning the camera off, open the battery door and take the batteries out. Leave it for a minute or two. This helps camera get reset and helps correct the basic functionality and also zoom error. Hope it helps u otherwise u will have to take it to authorised repair center. Good Luck.
Dec 03, 2008 | Fuji FinePix S7000 Digital Camera
The manual describes all warnings the camera displays. Check the manual or go here for the manual online in pdf format.
http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S7000Manual.pdf
Dec 13, 2007 | Fuji FinePix S7000 Digital Camera
Zoom error message
The higher end fuji's are good cameras. The A345 and A350 are a piece of crap. Low end Walmart cameras.
Oct 29, 2007 | Fuji FinePix A345 Digital Camera
Zoom error
No solution repair probably as expensive a replacement Contact Fuji the do a swap out at a discount service
Jun 23, 2007 | Fuji FinePix A360 Digital Camera
FUJIFILM FinePix S100FD Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
