Question about Canon Pixma iP4500 InkJet Printer
Every time I try to print (documents) it tells me to load the cassette, I set the printer preferences to only use the rear try and it still gives me the error message saying that it needs paper in the cassette, any suggestions?
  • 54 Answers
Press *+#+power and ok to format
Posted on Jun 06, 2010
My Epson Artisan 7-110 keeps trying to print to cassette 2 (small cassette) even when copying A4. A4 paper is loaded in Cassette 1. Why?
If its not a setting problem, it may not be communicating with your computer properly, try turning it off, wait a little while and turn it back on, if that doesn't work delete your printer off your computer and re install it, Is it the default printer on your computer? some times if you run more than one printer from your computer there's a conflict which can make it behave in weird and wonderful ways.
Sep 22, 2014 | Epson Artisan 710 AllInOne InkJet Printer
The document in the queu is requesting us to load paper in tray 1, but it doesn't recognize the paper. Any time we send a document through, it tells us this message.
Pull the cassette all the way out and look inside the machine for a piece of paper jammed against the real wall. If not ck the cassette for correct settings.
Feb 10, 2011 | HP LaserJet 4730mfp All-In-One Printer
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
We have a printer (MX870) that keeps giving us an error stating: there is no paper. There is paper in it but we cannot get it to print...it continues to give us the same error
From the service manual about the paper issue this is what it says:
***Rear tray. There is no paper. Load paper and press [OK].
Confirm that the rear tray is selected as the paper source. Set the paper in the rear tray, and press the OK button.
***Cassette. There is no paper. Load paper and press [OK].
Confirm that the cassette is selected as the paper source. Set the paper in the cassette,
Hopefully its just a setting on the printer or the computers printer properties.
Best of luck..
Jul 06, 2010 | Canon PIXMA MX870 Wireless Office...
Canon MX860 prints crooked!
Does this happen when printing from the cassette (bottom tray), or the sheet feeder in the back, or both? Check that the paper guides are set snugly (touching but not buckling the paper) against the edges of the paper.
Apr 29, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Messege * load mp tray * but tray has plenty of
MP tray is not the cassette it this flap that pulls down above it.
The machine will revert to asking to place paper in its MP tray when the information it is receiving about the document from whatever program tell it that the size is not the same as what the cassette is set to...
so, check page size in of document in word program or whatever you are using
also check paper type and size settings match those you just checked in the printers properties under printers in control panel.
If you put a piece of paper in the MANUAL BYPASS TRAY bot the cassette it will print on that.
To get evverything back to normal, turn off printer, delete jobs in print que, change paper size of document in word/excell/etc is set same as paper type in printer, print again.. all should be good...
p.s. these are good quality printers that why I bother to answer you... cheers
Nov 12, 2009 | Kyocera FS-2000D Laser Printer
Hi I have a kyocera C5015Nand it keeps telling me to load MP 4 try can you help please
to get the print press down arrow key it will show use alternative paper ? in display then press two times enter key it will print.............
its is the problem with the document page setting which one you giving print .......... its shows because its asking the paper according the document page setting ..........
Oct 17, 2009 | Kyocera Mita FS 3800 Laser Printer
Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Jun 02, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Cant print or scan
Hi carla;
that sounds pretty weird but you may want to try resetting it to default factory settings,just navigate through the menu if it still doesnt work, try re-installing the driver.
thanks
Jun 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
When I try to print to my laser printer MF4150, it prints one copy and the error light comes on and ithas LOAD CORRECT PAPER CASSETTE :A4 I pulled the paper out and reloaded. I Looked in my BASIC GUIDE...
Go in (win xp)
control panel
printers and fax
right click on the printer giving problems
click on properties (down the list)
click on printing preferences
on page size, switch from A4 to letter
click OK
Have a nice day
May 01, 2008 | Olympus P-11 Thermal Photo Printer
Canon Pixma iP4500 InkJet Printer Logo
139 people viewed this question
old marine
old marine
