Question about Kenmore 24032\24036 Top Load Washer
WATER FILLS WONT SHUT OFF - Kenmore 24032\24036 Top Load Washer
  • 54 Answers
The pressure swith (load size) is what controls that chang that. A small hose runs from the bottom of your tub and as the water fills a measerd amount of water fills that tube and pressure build up in their operates that switch and activates the timer to stop filling and start agitating.
Posted on Jun 06, 2010
WATER WONT SHUT OFF
. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Feb 12, 2013 | Bosch Axxis+ WFR 2460 Front Load Washer
Water wont stop filling in tub. have to shut water off manually
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Aug 21, 2011 | Kenmore Washing Machines
Water keeps running and over fills wont shut off
heatman101
Apr 26, 2011 | Kenmore Washing Machines
Water wont shutoff when filling
if you unplug the machine and it still fills with water, Then your water valve is bad, Use the wall shut off to find out what side is bad by turning on one at a time so you can find out if hot or cold valve.
if the water quits filling when you unplug the machine then you have a water level switch problem or the water level switch hose is disconected or cloged.
Sep 02, 2010 | Whirlpool Washing Machines
Fills up with water and won't stop!
This is caused by a faulty water level switch. It's a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain point it activates the switch to shut off the water. Make sure that the plastic tube is not damaged or obstructed in any way and the switch can be tested using a multimeter or ohmmeter and checking continuity. A lack of continuity will mean a faulty switch. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 29, 2009 | Washing Machines
Water fills up in tub but wont shut off flooded
Sounds like a problem with either the inlet valve or the pressure switch, the way to determine which is bad... while the machine is filling pull the power plug..if the water keeps filling it's the inlet valve that is going to be bad..if it stops filling it's going to be the pressure switch. The pressure switch is located in the control panel and has a small rubber pipe attached.once you have figured which it is replace it good luck.
If you have any other questions or concerns please feel free to comment again..Mike
Jul 25, 2009 | Kenmore Washing Machines
Fills with water when not in use.
Hi, If the washer fills up when off, you will need to change the inlet mixer valve. Do you have to shut the water source valve off to keep it from filling up?
Please let me know so I can assist you further.
Thanks
Vic
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Fills up with water and wont stop
if it still fills , with power off, the valve is letting by water and has become faulty,if water stops with power off,check for smudged powder at the lower part of the pressure switch pipe giving a false read to pressure switch,other than that the pressure switch has become faulty,look at the pressure switch pipe first for blockage,hope this helps
May 07, 2009 | Whirlpool WTW5200S Top Load Washer
Bad Preasure valve comes to mind first and formost it acts like a level sensor balanceing the size indicated for fill.
Feb 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Hot water wont shut off
solenoid valve is jammed open
replace
Mar 31, 2008 | Kenmore 24902 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
91 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
