Home | In Dash Receivers | Clarion CMD4A Marine CD ...
In Dash Receivers
Problem for In Dash Receivers
Generic problem for all In Dash Receivers
Clarion CMD4A Marine CD player
By bretl on Apr 10, 2008
it just turns on by itself. changes stations. also changes from cd to satilite, to fm to aux. to mut. no rhyme or reason. this is my third clarion.. am I nuts?
Comments:
Apr 10, 2008
- I just replace it lat night with a new one, 20 minutes later, turned on by itrself an started changing again by itself..
Solution #1
posted on Apr 10, 2008
Not Rated)
Jaime867
Rank: Guru
Rating: 88%, 953 votes
It seems that there might be a loose contact somewhere the power wiring.
Have you check that?
Is very unlike that 3 devices have exactly the same failure.
Comments:
Apr 10, 2008
- Check the connector that has all the wires for oxidation and you might need to clean them with rubbing alcohol.
Solution #2
Not Rated)
Basti
Rank: Wiz
Rating: 85%, 779 votes
There is something on the connection because it is repeatatively sending infos to your player, try to disconnect it and try checking the cables on how you set it up.
Comments:
Apr 10, 2008
- Just try to connect the power source to it and turn it on, if it give you the same results, Hardware issue. If not then try plugging other cables one by one.
Solution #3
Not Rated)
coolguy008
Rank: Wiz
Rating: 83%, 565 votes
The only solution to fix this problem is to get it serviced or just replace the unit if it is still under warranty.
You can try out a hard reset by unpluggng the unit for 30min and then plug it back.
Goodluck,
Please don't forget to rate the solution.
Popular Solutions for In Dash Receivers
Questions and Unsolved Problems for In Dash Receivers
Answer
just bought the metra 70-1856 by pass wiring harness. of course, there weren't any directions with... (More)
Answer
securty code reset on my kenwood kdc-mp43bu
Answer
my volume only go to 14 what can i do to correct this
Answer
I just can't seem to find the correct button or buttons so I can adjust my clock to the correct... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For In Dash Receivers:
Top In Dash Receiver Experts
Rank: Guru Guru
Solutions: 14126
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more In Dash Receiver Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
