I have a 1977 Yamaha DT400 that i'm tryng to get back on the road again. I'm having trouble getting the headlight to work. I have installed a new battery, checked and replaced the 10 amp inline fuse and i have good power to the handlebars. The blinkers work, the taillight/brakelight works, but I can't get any power to the headlight. I checked the headlight plug for ground and that's good, just no power at all. I have the tank off and i can chase the complete wiring harness up to the front and it appears to be in good shape, no obvious worn spots that would make a short anywhere. Is there a common problem that occus with these bike that I may have overlooked? (such as the rectifier) Thanks in advance for your imput. Mark.
  • 4,737 Answers
Please cancel this post and again repost it on the "Motors" category. You've posted it on the "Website" category, it'd be difficult for the Motors expert to track your post. (Please, this is only a suggestion so that you can find the category expert easier.) Thank you.
Posted on Jun 06, 2010
2014 yamaha roadstar silverado manual
Available from a link on this page, but 10 bucks. They mention 'Paul's site' for free.
Yamaha do have manuals available for free although these tend to be owners manuals. Worth a look though.
http://www.yamaha-motor.eu/rs/services/owner-manuals/index.aspx
Re Complete Factory Service Manual Downloads Road Star Forum Yamaha Road...
Jan 19, 2016 | Yamaha Motorcycles
Yamaha 80 vin#1T0-006931what year of dirtbike do I have? Does it have title?
it is a 1977 yz80D and its a little off road bike, sorry no title, there is in fact a 3 digit code on every yamaha you can identify it by , you just need the resources to do so.
Aug 31, 2015 | Yamaha Motorcycles
Yamaha v star
Hi, Anonymous if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
5. Faulty ignition switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Re Grrr Headlight keeps blowing fuses Road Star Forum Yamaha Road Star
Keep blowing headlight bulbs
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
May 13, 2014 | Yamaha V Star 1100 Classic Motorcycles
Intermittent spark on a 1977 Yamaha 440 exciter
check and or test your throttle switch. they are known to go bad and cause this trouble
Jul 18, 2017 | Motorcycles
Free 1977 yamaha dt400 manual
Hi, Anonymous the vast majority of service, parts, and owners manuals on the internet are "FREE" to download and all service manuals contain wiring diagrams in the back pages. The rest usually charge a modest fee around $10 and there is a handful of obscure, rare, obsolete, and very old models that are no longer or never were available, then there is eBay where you may be able to find what you need at a very high price because of its age and rarity. Most of the "FREE" manuals will cover your exact make, model, and year otherwise one will be provided that comes as close as possible to your bike and will have most of the same info that an exact manual would have. To download your manual please click on the links below. Good luck and have a nice day.
Yamaha DT400D Manuals
http://mybikemanuals.com/yamaha/yamaha-dt
Aug 23, 2013 | Yamaha DT 360 Motorcycles
2005 1700 warrior has no power to headlight or dimmer fuse good, new light
Hi, Warren if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Headlight Won Light
Headlight stopped working
Yamaha XV1700PCRC Service Manual
Yamaha XV1700PCR Road Star Warrior Owner Manual
Jan 31, 2013 | 2002 Yamaha Road Star Warrior
How to set timing on 1975 yamaha dt400
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $9 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Vintage Enduro Discussions 1977 DT400 timing marks 1 2
Help with timing on DT400
YAMAHA DT250 DT400 SERVICE REPAIR WORKSHOP MANUAL 1977 1979 Download...
Aug 09, 2012 | Yamaha DT 360 Motorcycles
Were can i get a headlight bulb for a 1972 yamaha 250 enduro
Hi, Anonymous the answer to this question is way above my pay grade and for this situation, I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Yamaha DT 250 Headlight eBay
http://www.ebay.com/itm/New-6-Volt-Motorcycle-Headlight-Bulb-Yamaha-DT175-DT250-DT360-DT400-Enduro-6V-/272184455526
Yamaha DT250D Service Manual
Yamaha DT230 Owner Manual
Mar 11, 2012 | 1972 Yamaha DT 360
I have a 1975 dt400 that I converted to points from a 1975 dt250.The bike runs well but the system is putting out 45 volts when it is running.obviously my bulbs don't like this over voltage where do I...
Hi, James4570 a voltage regulator comes to mind but the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
http://64.234.201.42/yamahasnitz/topic.asp?TOPIC_ID=151
75 dt400 ignition Vintage Enduro Discussions
Jul 28, 2011 | Yamaha DT 360 Motorcycles
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
