Having trouble using and understanding Cd mastering to make CD on the roland 2480 dvd workstation
    Genius:
  • 1,142 Answers
How are you trying to make the cd on roland 2480 dvd workstation
Posted on Apr 10, 2008
  • 2 more comments
  • Maanita Chadha
    Maanita Chadha Apr 10, 2008
    To get the most out of your VS-2480, add a Song Vault (I archive
    projects to it rather than make CD backups, which can be
    time-consuming), Roland's MB-24 Meter Bridge and an external VGA
    monitor. Also invest in a mouse and keyboard — the wireless varieties
    are especially useful. Many VS-2480 functions can be performed using
    either the unit's control surface or mouse/keyboard equivalents. Most
    of my tips include mouse/keyboard commands, but you should learn
    several ways to perform your most common operations.
    SAVE, SAVE, SAVE
    You might think this goes without saying, but
    at one time or another, everyone has lost at least one “perfect take”
    because they forgot DAW recording's Golden Rule. There are three
    different ways to save your work on the VS-2480. Using the mouse, click
    Project Menu, click Store and then click Yes. Using the keyboard, press
    F9 (Project Menu), arrow down to Store, press Enter and then press
    Enter again to confirm. From the VS-2480 console: Press and hold Shift,
    press Store (the left transport button) and then press Enter to
    confirm.
  • Maanita Chadha
    THERE ARE SOME ADDITIONAL TIPS WHICH MIGHT HELP YOU U IN FUTURE. ENJOY.........
    ONE BAND, MANY SONGS
    If you're working with a band that's recording
    many songs during a session using the same track setup, configure
    patchbay routings and name tracks, set up the first song, and before
    recording store it! Then open it again and copy the project. Make as
    many copies as you need, but remember to go back and change the project
    names; otherwise, all will come up with the same name until you do so.
    Using the mouse, click Project Menu, click Project List, mark the
    project you want to copy, click to page 2, click F1 Copy and then click
    F5 OK. If you want to save to a different drive, then choose that with
    F4 Sel Drv before selecting F5 OK. If you had changed settings that you
    would like to keep in this project “template,” then you can easily
    transfer those settings to a new project (without audio tracks) if you
    turn on the “Copy Utility Prm” settings when creating a new project
    from the File menu. The settings from the previous project will be
    imported automatically.
    SAVING ROUTING
    Sometimes, a project has many songs, and while
    the band's setup remains the same, not all tracking will be the same.
    Or perhaps the project will not all be done on the same day. In such
    cases, you should save a Routing Template. This is also a helpful
    feature when using the VS-2480 for live sound applications. Using the
    mouse, click EZ Routing Menu, click Routing View and make all your
    routing settings; click Routing View again and then click Save. Then
    choose a User Template: Click F1 Name to name your setting and then
    click OK. To recover a setting, use Routing View and Load.
    MAKING TIME
    The VS-2480 does have an internal metronome
    with a tempo map feature, but there are times that you may need an
    actual click track. First, make your metronome and tempo map settings.
    Then click Utility Menu; click Gen/Osc, click SW to On, click Source to
    Metro and click F6 Exit. Click Routing View in the Track Assign section
    to make the connection from Gen to the track you want to record to and
    then simply arm the track for recording.
    UTILITY SECRETS
    Like many other digital toys, pressing some
    odd combination of keys can yield useful results. For example,
    determining your VS-2480's software version (the most current version
    is 2.504) is easy: Power the unit down. Then press and hold Track 1's
    Channel Edit and Track Select buttons while powering the unit up. The
    LCD will show its software version. Press Enter to complete startup of
    the unit. Another slick trick: Pressing the Shift and Utility buttons
    at the same time will shift the mouse functioning from the LCD readout
    to the VGA screen. The function will change each time you do this.
    PAN-O-RAMA
    The VS-2480's pan knobs normally change pan
    values in increments of 10. To make adjustments in single-digit
    increments, simply hold the Shift button down while using the pan knob.
    Speaking of pans, you can return any track or input fader to the
    default 0 dB and center panning by just pressing Clear and Ch Edit for
    any fader you want to restore.
    GET BACK
    Keyboard transport is possible on the VS-2480, yet there is no simple
    way to return to zero. However, you can get around this by using your
    locate points. First set a locate for zero and for any other spots in
    the project you'll want to access. Then, using the keyboard, press F12
    (Utility Menu), arrow down to Locator, press Enter, use the arrows to
    get to the desired Locate point and press F4 Go To.
  • Maanita Chadha
    *****PLEASE DONT FORGET TO RATE FIXYA******
  • Maanita Chadha
    The url might be of some use to you.
    http://www.shyan.in/Products/VS2480CD/VS...
ROLAND 2480 RECIEVE ERROR MESSAGE SUB SYSTEM NOT RESPONSE
This means the low-level part of the operating system is corrupted or missing. Simply try reloading the OS by putting the CD into the CD drive. If it does not allow an OS reload or if it fails, most likely the flash ROM which holds the basic part of the OS has been zapped and will require service. You can also try to replace the internal button battery inside that retains the memory.
Aug 24, 2012 | Roland Vs-2480 Digital Recorder Loaded...
Problem getting VS-2480 to connect to internal drive. also to external drive sometimes it works sometimes it won`t Need service manual for mounting new harddrive internally SATA 160 GB Experienced...
Hi Karl,
First of all, thank you for purchasing the copy of Roland VS-2480 Service Manual.
Please email me at mjsvillanueva23@yahoo.com, I will send you the copy.
May you and your family have "Prosperous New Year 2012"!
Again, thank you so much!
Mjsazon
Dec 29, 2011 | Roland Vs2400CD Digital Workstation W/CD...
Roland VS 2480 v2 - working on album and received error message "load project please wait" since last night. have tried turning machine off and on and unplugging it. still same message.
Hi, have you tried to do a factory reset?
Hold SHIFT and press F4 (Utility). Press PAGE to get to page 3. Press F6 (PrmIni). Press F5. Press ENTER/YES.
If the factory reset does not fix the problem i think you have to format the disk because it has a fragmented disk .......
Dec 12, 2010 | Roland Vs2400CD Digital Workstation W/CD...
When I turn on my roland vs 2480 it never makes it past the load project start up screen. What can I do? please help
moz-screenshot.pngHave you tried to do a factory reset?
Dec 03, 2010 | Roland Vs2400CD Digital Workstation W/CD...
Lost f/x across all tracks prior to Mastering on Roland 2480cd
Double check that you haven't inadvertently muted or turned down the effect returns. Also make sure they haven't been inserted elsewhere as they wont work as post effects while inserted into a single channel. If you are using some effects, it will cancel the effect card's ability to use its second channel. (ex. mastering suite)
Feb 17, 2010 | Roland Vs2400CD Digital Workstation W/CD...
My Roland VS880ex won't recognize the 525
These can be very finiky regarding the CD burners.
I would suggest you visit the site:
http://www.vsplanet.com/
Lots of info there regarding these issues.
AS I RECALL there are TWO different downloads and one will allow the burning BUT will not allow another feature to work. The site should have the info you need.
Oct 22, 2009 | QPS Que! USB 2.0 Drive CD-RW Burner
Low Volume on CDs - Roland 2400 CD
Hey Rick, There are a couple of places to look; I'll assume you have a decent input level near -12db average without peaking. First, ensure during playback upper right meter labled MST is near peak without going over, if you have room push the master level above 0db to +1 thru +6db and recheck for peaks above 0db. (You never want digital recordings to hit above peaks, you lose quality or resolution of the sound) As you find the sweet spot, master rec to 23/24-16 using the elevated level on the master fader. The manual suggest editing and mastering with the master fader at 0db however if you don't compress your tracks individually or reprint them at higher levels, you may have a great mix at an overall lower volume, pushing the master fader should help for a quick fix, but if this cures the level issue, try compressing and leveling each track to peaks prior to the first mix only lowering tracks which are too loud, when you get to mastering, all your signals are at their top potential for the CD. Spend a few minutes burning samples at low, just below peak, and just above peak levels on separate tracks and playback in your boombox for reference to a commercial CD. You'll find little to no difference when you are in the sweet spot. Another trick is to mixdown to a separate pair of tracks (not 23/24-16) and compress again during master mixdown rec. (ultimately 23/24-16) Good Luck Jeremy Yates, Radio World LLC.
Jan 08, 2009 | Roland Vs2400CD Digital Workstation W/CD...
I need to find a place to buy one roland vs 2480 cd replacement fader board
You should contact Roland to find out who their parts dealer is for your area. Once you are on their site, click on the Support tab.
http://www.rolandus.com/
Jerry G.
Jun 04, 2008 | Roland Vs-2000CD Digital Studio...
"Setup Drive: Load Project -> Now working... -> Please wait...."
I have 3 2480s and I use them professionally so I think I can help you. Looks as if you need to install the OS for the system. It seems as if it lost. You should have the OS on CD and if not contact RolandUS and get one. You would put in the OS into your CD burner and power up the unit. I would recommend Roland HD support be on the other end if you are brand new. They will walk you through. I was one of the first to buy the 2480 when it came out and the manual is just insane to learn.
Mike
Apr 12, 2008 | Roland Vs-2000CD Digital Studio...
Roland VS-2480 DVD Workstation
have problem with vs 2480 anyone fixes  roland vs  2480
Apr 10, 2008 | Audio Players & Recorders
51 people viewed this question
 Grubhead
Grubhead
