Question about Whirlpool LSN1000LW Top Load Washer
The colded water comes out very very slow
The cold water comes out very slow and not at full pressure. It takes up a long time to fill up when doing cold wash. When you use the hot water option it comes at full pressure. I have checked the line coming into the washer and it is at full pressure. Do you have any suggestions???
  • 54 Answers
Change yhour water valve the rubber in side the valve wear out. switch your hoses at the wall and you will see what I mean.
Posted on Jun 06, 2010
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
Washer taking a long amount of time during cold wash and rinse cycle.
check the screen in the cold water entry these sometimes get clogged and cause the cold water to come in too slow and will take a long time to fill if sceen is clear a new water valve may be needed
Feb 22, 2011 | Whirlpool Washing Machines
My Fisher and Paykel IW812 washing machine only has a slow fill on the cold water. Tap pressure, hose and inlet screen appear normal. Thoughts?
Yeah if the filters are clear and your water pressure is good replace the inlet valve, i believe on that model the hot and cold come as one assembly which is pretty easy to replace if you take the top off. What happens is part of the valve's inner workings called the diaphragm can devalop a split which'l cause it to fill only slowly
Apr 26, 2010 | Fisher Washing Machines
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Feb 22, 2009 | GE WJRR4170E Top Load Washer
Slow fill on cold water/Fisher&Paykel GWL11
Assuming you have already done what you said you have done, now it is time to do some real troubleshooting.(Dont worry, if you have gone this far you'll be able to do what I'm going to tell you)
First take the lid off. To do this, open it, and lift up on one side, it should come right off. Now take the control panel cover off. There are two screws on the back side of the washer holding it on. You'll need to wiggle it a bit to get it off. Once the cover is off you should find a plastic bag with a "service" sheet in it. The service sheet explain how to put the machine into the "Test Mode". This is very easy to do and will allow you to check out all functions. One of the test, allows you to check the cold water inlet valve. Assuming your water pressure is good and you have indeed cleaned the screen filter going into the machine you will most likely find that the cold water valve is not opening all the way and will need to be replaced. If your handy with a phillips screwdriver you only have two more screws to take out and the valve assembly will come right out.
Don't think you can swap out the hot water valve with the cold water valve. Fisher Paykel, clever as they are made sure you can't do that. One is a proportional valve and the other is a digital valve. They both look identical but they are not!
If your going to do the repair yourself (you've come this far, why not see it through to conclusion), be sure when you call Fisher/Paykel to order the cold water inlet valve that you give them the serial number of your machine to be sure you get the correct part.
Good Luck!
Jan 19, 2009 | Fisher and Paykel GWL11 Top Load Washer
LG WF-T652A Slow water fill
Probably dirty filters in the inlet part of the washing machine. I had the same problem with this model.
Jul 29, 2008 | Washing Machines
Kenmore washer
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still slow, replace valve. As far as the spin is concerned, inspect the bottom of the gearcase for oil. If oil is present, the oil has migrated to the clutch causing it to slip during spin.
Jun 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Slow rinse cycle fill
take the hose off the cold water valve and check the screen on the water valve ,make sure the cold water is on all the way and the hoses are on the right valves get a water bucket hold the cold water line in it open the cold water valve to check the pressure
Jan 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool LSN1000LW Top Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
