Question about Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000
Keyboard stopped working....changed batteries...still doesn't work....can't find manual...what connects the keyboard to the computer?
sandrew
  • 2961 Answers
SOURCE: Logitech cordless keyboard 3100 not working
the problem with cordles keyboards is that the transmitter/receiver works via usb and sometimes the driver does not have time to load for the system to start leaving it dissabled, the reason for this is whts called IRQ interupt requests. Some usb ports get left to the back of the queue when requesting that they need to start up, so unfortunately this is a common fault and may be sorted by trying the keyboard in different usb ports and moving any other peripheralls to different ones, although you will have to reinstall all the drivers as you will be using different ports, so install the keyboard first and then it may get an IRQ of 1 which means 'start me first'
Posted on Sep 09, 2007
SOURCE: Microsoft wireless keyboard stopped working (mouse still works)
press the connection button on the receiver. it worked for me. it took me a while to figure out there is a connection button on the receiver as well as the mouse and keyboard.
try it!
Posted on Feb 08, 2008
CTRL-ALT-F12 by itself finally did the trick!!!
Thanks!!!!!!!!!!!!!!!!!
Posted on Jun 20, 2008
SOURCE: Vivanco remote keyboard not working - remote mouse still working
I replaced the keyboard with cheap one and that works straight away. Uninstalling the drivers fro the old and re-installing hasnt worked so assume remote keyboard has failed electronically. However the fault came on straight after a windows automatic update so could be a problem in that. I have not got any expertise on computers so will let it rest at that until someone more adept can look at it.
Posted on Mar 31, 2009
tommya300
  • 724 Answers
SOURCE: Keyboard stopped working. Changed batteries and
Does ther del have an external remote module that is connecter to the computer where a standard mouse and b connects. see if the connection is there anything here is possible
Posted on Jul 27, 2009
My nextbook ares 10l keyboard stopped working
If your USB Keyboard stopped working, you can try to disconnect it and connect it back on the fly. USB connections are plug and play, so if you are running Windows and your USB keyboard doesn?t work, you can try unplugging and plugging it back to re-establish the communication, or simply try connecting it to another USB port. If this still doesn?t work, check the led lights on the keyboard; are any of them on? If they are, is the computer acting slowly? You may need to restart it at this point to refresh your computer memory and resources to get it back to normal speed, or perhaps it needs maintenance by running disk cleanup and defrag it
Nov 28, 2016 | Nextbook Tablets & eReaders
My Logitech Pro 2800 keyboard has stopped working.
My Logitech Pro 2800 keyboard has stopped working Google Search ..go to this google link and you will see a list just look to see what one might help you out.
Nov 27, 2016 | Wireless Computing Computers & Internet
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
How can i connect my ex110 with computer
Hello there.
  1. If your wireless keyboard came with a software CD, install that first.
  2. Then plug-in the USB receiver it came with it on a USB port on your computer.
  3. Put all the batteries on the keyboard and mouse.
  4. If it doesn't work, you may find a Connect button under the keyboard and / or mouse.
  5. You can find drivers and manuals for your keyboard and mouse here: http://www.logitech.com/en-au/433/154
Aug 21, 2011 | Logitech Cordless Desktop EX110
My wireless mouse stopped working. I've changed
there should be a connect button on the bottom of the mouse, if that doesnt work try removing and reinserting the usb receiver on the computer itself.
Dec 21, 2009 | Computers & Internet
Dell wireless keyboard stopped working. Changed
I make oresumption that you have depressed the connection button under the keyboard to reset it?
If still a problem go to device manager and delete the wireeless keyboard so it can be discovered again.
Please rate my help++++Thanks for using FIXYA
Nov 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Jul 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Wireless keyboard and mouse stopped working
Simple dear first of replace the battery with new one and than press the connect button on sensor. or if u r not able to get out than change the polarity of the battery by changing there position.
Jan 29, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000 Logo
207 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
