Question about Whirlpool LEQ9858P Electric Dryer
I hit the stat button and i here a click from the swich but it does not activate. I took switch appart and the relay is making contact but the drier is not turning on?
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryeri hit the stat button and i here a click from the - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_noi hit the stat button and i here a click from the - 2_bing.gif/a>
Dryer Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 06, 2010
Bike quit starting. Took starter to dealer said it was bad. New starter still does not start.
Hi, J a motorcycle starter relay is an electronic mechanical switch that has a small coil winding around a piece of metal that requires low amperage and thin wires to be activated. When you turn on your ignition switch power 12 volts is sent to the relay coil which in turn becomes a magnetic contact point that pulls a spring-loaded contact point to itself completing an electrical circuit that allows more amperage necessary to be accessed by the starter solenoid which in turn acts in the same way as the relay but on a larger scale with its stronger heavier contacts making available the necessary amperage to turn the starter motor. If your battery has low voltage it, in turn, makes the magnetic contact point weak in trying to pull its counterpart to make a connection. These relays are usually encased in a plastic housing that may or may not be sealed depending on the quality of the product. When activated they will produce a small amount of heat to their metal components which in turn can create the perfect environment for condensation to form depending on weather conditions and how careless you may be with a water hose or sprayer while washing your bike. After a period of time, several months to several years depending on circumstances this condensation is the start button for electrolysis and the slow build up of corrosion which ends by preventing the magnetic contacts in making a solid connection and alerts you to this situation with the customary greeting "CLICK". The relay is inexpensive and needs to be replaced however in a pinch they can be forcibly opened cleaned and resealed with silicone. In a nutshell, motorcycle starter relays take in low amperage and send out higher amperage when activated and for curious minds, the voltage remains constant at whatever your battery reads at the time, this is why a fully charged battery 12.5 volts or better is the best insurance on preventing starter motor problems and increases the longevity of all the starter circuit components. Good luck and have a nice day.
Jan 24, 2016 | Motorcycles
When i press the start button on my buell motorcycle the lights work but the bike will not start i hear clicking sound in fuse box
Hi, Anonymous a motorcycle starter relay is an electronic mechanical switch that has a small coil winding around a piece of metal that requires low amperage and thin wires to be activated. When you turn on your ignition switch power 12 volts is sent to the relay coil which in turn becomes a magnetic contact point that pulls a spring-loaded contact point to itself completing an electrical circuit that allows more amperage necessary to be accessed by the starter solenoid which in turn acts in the same way as the relay but on a larger scale with its stronger heavier contacts making available the necessary amperage to turn the starter motor. If your battery has low voltage it, in turn, makes the magnetic contact point weak in trying to pull its counterpart to make a connection. These relays are usually encased in a plastic housing that may or may not be sealed depending on the quality of the product. When activated they will produce a small amount of heat to their metal components which in turn can create the perfect environment for condensation to form depending on weather conditions and how careless you may be with a water hose or sprayer while washing your bike. After a period of time, several months to several years depending on circumstances this condensation is the start button for electrolysis and the slow build up of corrosion which ends by preventing the magnetic contacts in making a solid connection and alerts you to this situation with the customary greeting "CLICK". The relay is inexpensive and needs to be replaced however in a pinch they can be forcibly opened cleaned and resealed with silicone. In a nutshell, motorcycle starter relays take in low amperage and send out higher amperage when activated and for curious minds, the voltage remains constant at whatever your battery reads at the time, this is why a fully charged battery 12.5 volts or better is the best insurance on preventing starter motor problems and increases the longevity of all the starter circuit components. For more information about your issue, please visit the websites below, and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have a nice day. Clicking relay what could cause that SV1000 Portal
Buell XB clicking starter problem
http://www.steveturnbull.co.uk/buell/buellmenu.htm
TWIN Motorcycles Buell parts
Buell Motorcycle Owners Manuals
Jan 25, 2014 | 2007 Buell XB12X Ulysses
1994 nissan pickup a/c will not come on when i push the button, wont light up.Blower works fine, if i bypass the relay a/c works and it has enough freon. the relay is also good, could it be the a/c switch?
Yes the AC compressor swich could be bad, you could check switch continuity possible bad contacts. Also check to make shore you have proper DC voltage supplying switch, should be 12 volt DC.
Jul 01, 2012 | 1994 Nissan Pickup
I replaced fuel pump on 96 ford explorer now fuel pump wont turn on is there a relay or reset switch
There is a fuel pump cutoff reset button (and a relay) it is located under the instrument panel at the right (passenger) hand cowl side "kick" side panel, press the button and when you hear a click it is reset.
Jun 05, 2012 | 1996 Ford Explorer
2005 Honda VFR 800 clicking noise when starting
Hi, Nick before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries. Depending on battery voltage starter relays and starter solenoids can make the same noise when you hit the starter button. You can easily determine which one is at fault by two simple tests:
STARTER RELAY- place your thumb and index finger on the starter relay and press the starter button, if you feel the click then the relay is faulty and needs to be replaced.
STARTER SOLENOID- bridge the positive and negative poles of the solenoid with a small screwdriver if you get a loud clunk then the solenoid needs to be rebuilt or replaced as necessary. If the engine turns over then replace the starter relay.
A motorcycle starter relay is an electronic mechanical switch that has a small coil winding around a piece of metal that requires low amperage and thin wires to be activated. When you turn on your ignition switch power 12 volts is sent to the relay coil which in turn becomes a magnetic contact point that pulls a spring-loaded contact point to itself completing an electrical circuit that allows more amperage necessary to be accessed by the starter solenoid which in turn acts in the same way as the relay but on a larger scale with its stronger heavier contacts making available the necessary amperage to turn the starter motor. If your battery has low voltage it, in turn, makes the magnetic contact point weak in trying to pull its counterpart to make a connection. These relays are usually encased in a plastic housing that is sealed depending on the quality of the product. When activated they will produce a small amount of heat to their metal components which in turn can create the perfect environment for condensation to form depending on weather conditions and how careless you may be with a water hose or sprayer while washing your bike. After a period of time, several months to several years depending on the circumstances this condensation is the starter button for electrolysis and the slow build-up of corrosion which ends by preventing the magnetic contacts in making a solid connection and alerts you to this situation with the customary greeting "CLICK or BUZZ" if you get a single loud "CLUNK" then the starter solenoid is at fault and needs to be rebuilt or replaced as necessary. The relay is inexpensive and needs to be replaced however in a pinch they can be forcibly opened cleaned and resealed with silicone. In a nutshell, motorcycle starter relays take in low amperage and send out higher amperage when activated and for curious minds, the voltage remains constant at whatever your battery reads at the time.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Please help 1200DCT won start Clicking noise when pressing starter
just clickity sound when pressing start
2002 Honda VFR800 VFR800A Interceptor Service Repair Workshop Manual... $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda VFR800A 2005 Owner Manual
Mar 27, 2012 | 2005 Honda VFR 800
1982 Honda VF 750 S will not start just rapid clicking
Hi, Garrison_728 before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries. Depending on battery voltage starter relays and starter solenoids can make the same noise when you hit the starter button. You can easily determine which one is at fault by two simple tests:
no start but clicks
Motorcycle not starting Clicking noises FIX
Honda 45 SABRE VF750S 1982 Shop Manual
Honda 1995 VF750C Magna Owner Manual
Aug 25, 2011 | 1982 Honda VF 750 S
I have a 2000 Honda Shadow 750 ACE. While riding at highway speed I accidently hit the kill switch. At first wasn't sure what had happened. Realized it was a fuel issue... noticed it was the kill switch....
Take the starter button off and put a 12 volt tester on one of the 4 leads that are wired into the button. Test each- If you find a hot line, take a small piece of wire and jump the current over to the other parrallel button. I worked on my bike for two weeks before I discovered this problem. Another problem was that the headlight would not come on. The starter would not crank at all. I took a screw driver and raised the brass leads on the switch so they would make contact and put the switch back together, and it worked. Good luck.
tim reynolds
Jul 18, 2009 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Will not switch on- button will not stay on
at the rere of the switch there is a small relay board. replace this and ur problem will be solved (ex hoover engineer)
Nov 25, 2007 | Hoover HDC6 Electric Dryer
Whirlpool LEQ9858P Electric Dryer Logo
69 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
