Question about Bionaire BT46R Tower Fan
My Bionaire BT90R stop working i think the motor
My Bionaire BT90R stop working i think the motor is gone.
have u got any idea were to get a new one motor
RE: Bionaire BSF1620RC Pedestal Fan - blades won't turn. I have had this fan for about 4 years - 2 of which the fan has been stored. It was well protected so I don't know why it isn't working. but the...
These run very small motors with low "starting torque" If the fan hasn't been run for a long time, its possible that it has jammed up or got tight from just sitting there. Being careful, turn on the fan and spin it in its usual direction by hand, it should start running. If you cannot spin by hand, it may have seized up which will require you to strip and lube the motor. If you manage to get the fan spinning , let it run on high fan speed for an hour or so, it should free up and then be OK again. A small spray of WD40, CRC or similar spray can lube on the fan shaft where it disappears into the motor may assist.
Feb 03, 2015 | Bionaire Dryers
Bionaire BAP1300 -- Working fine for 2 Days then, Red Light
Try to do a hard reset by unplugging the device from the power outlet and wait for sometime to reconnect.
Jun 09, 2008 | Bionaire BAP1300 Air Purifier
Bionaire BF1209R motor possibly burned out from a string caught in blades What are some solutions besides getting a new fan
The motor has a fuse buried in the windings near where the wires connect to the motor. Sometimes, if you're careful, you can expose the wires and jump around the fuse. Otherwise a new motor in in order.
Feb 23, 2014 | Dryers
I put a 3 amp in the plug and i heard a bang i tried another and it would'nt work? do you rhink the motor has gone and can i get it fixed?
like many electrical items there made for the right fuse or breaker to be ran off of the main box so there is a high odds your fan had to many amps going through it and very good that you blew the motor,you would have to replace the motor if you want it to run again.
Aug 02, 2011 | Bionaire BSF152TU Stand
My Bionaire BH1551 heater stopped generating heat. I had it running for one hour the fan works but no heat. Any ideas?
Hi; Broken heat element? Check the tip over switch on the underside? Any reset buttons?
May 06, 2011 | Heating & Cooling
Bionaire upright fan stopped blowing air
Throw it away. I have come to conclude that Bionaire is a junk brand that does not service their products. I have a bionaire model BCM646 humidifier purchased at COSCO and the water tank broke.
NO! I did not drop it, it just sat in the corner. I have not even used all the factory filters that came with it.
Who would have thought a made in China product (for American idiots) would break and not have replacement parts?
Such a shock considering their fine reputation.
Apr 01, 2009 | Bionaire BT45RC Tower Fan
Humidifier stopped working after cleaning.
It started working again on its own. Not much of a solution!
I think some water must have got into the electronics and then once it dried, the humidifier started to work again.
Christiaan
Feb 07, 2008 | Bionaire Warm Mist BWM0400-U Humidifier
Switch bad?
the switch has gone bad. the switch cannot be repaired but can be replaced
Dec 03, 2007 | Bionaire BH3900-U Oil Filled Radiator...
Oscillation stopped working!
Sounds like the drive gear is stripped.
Nov 20, 2007 | Bionaire BAP1500-U Air Purifier
Heater won't turn on, the lights keep flashing.
HI There is a product recall for this particular model of heater, you can search the internet for details on how to get the item collected by Bionair and get a full refund, these are a fire risk.
Jan 03, 2007 | Bionaire BH3930 Oil Filled Radiator Heater
Bionaire BT46R Tower Fan Logo
542 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
