Question about Euro-Pro Shark GI490 Iron
How do I take the iron apart. something loose inside
    Problem Solver:
  • 15 Answers
Umm i think you should consult an electrition incase something goes wrong
hope this helps!
Posted on Jun 06, 2010
Loose plate on a morphy richards comfi grip iron
Unless you want to strip it down and resecure from the inside, buy a new iron.
Jul 21, 2014 | Irons
Why do my straighteners keep turning off
I had the same problem. The solution was quite simple actually. I took the iron apart. The problem was that one wire got loose. I soldered it back where it belongs and now the iron works again.
CAUTION! This procedure should be done by a qualified electrician only!
Jul 14, 2014 | Remington S9500 Pearl Hair Straightener
How do IO remove the sole plate because a screw has come loose inside at the front making the sole loose
you have to access the iron from the top or from the heal. the base is solid and can not be accessed from the bottom look on the heal plate of screws then the top should lift foward.
I hope this was useful
May 01, 2014 | Russell Hobbs 15129 Slipstream Iron
Iron not heating
Hi nowlinwells
Check your power going to the iron...if you have power going to the iron then take apart the iron and check the connection inside of the iron because it sounds like the wire is broken and not getting power to the iron.
Please rate me.
Bud
Oct 06, 2012 | Sunbeam 4214 Iron
My iron doesn;t work after it fell ..my iron is a steam and nonsteam what will i do to fix this?
Something would of broken inside the iron, and you will find it dearer to Repair than to buy a new one. If your smart pull it apart and try to mend it yourself. sorry I cannot help you fix it.
May 19, 2010 | Tefal UltraGlide 1759 Iron
Russell Hobbs Steam Glide 2200 won't produce steam.
I had a problem and tracked it down to the pump. If you take the iron apart, the pump sits towards the front of the iron and has 3 tubes connected to it. Remove the srew-down bracket and free the pump from the plastic clasps on the base. Disconnect tubes and wires (remembering where they go.
Remove the circular securing spring from the front of the pump and drop the metal barrel from the housing. Unscrew the rear plastic assembly and set aside. there is a joint inside where the plastic assembly was - this is has an o-ring and is simply a pull-apart. It deos not need screwing. Pull the metal barrel apart, taking care to note the sequence for reassembly. Inside the barel is a larger rubber washer. Pull on the metal tube that goes through the centre of the washer using a pair of pliers - it will come free.
You will then see the problem - the spring inside the metal barrel will have broken. Take care, because at the other end of the spring is a small plastic washer that must be retained. Find a pen that has a short spring inside and use this as a replacement. If necessary, you can trim the spring to make it the right lenght. Ensure you have removed all broken pieces of spring, and reassemble. Try it out before finally attaching the pump inside the iron. It took me 2-3 attempts to get the spring tension right. If you can find a 'PENAC RB-085B BA1002' pen, the spring is perfect.
Once you have got it right, reassemble.
I have to replace the spring approx every 6 months as the replacement is obviously not meant for the job and wears or rusts or breaks. However, I am getting extended use from my otherwise broken iron.
Take care - things inside get HOT!!
Hope this helps.
Oct 22, 2008 | Irons
Open Iron
on most common IRONS , theres a screw located on the back where the main cord is , underneath it , AJ
May 15, 2008 | Sunbeam Classic 3957 Iron
Water leaking from iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Feb 06, 2008 | Sunbeam Classic 3964 Iron with Auto...
Spray broken, can't figure how to take apart to check
You've to open the unscrew the rear screw and take out the rear cover.It's quite hard to fix it if you don't have the schematic diagram. Suggest you odd to have the iron schematic to have step by step as for your easy guide reference.
Rdgs
alan
Nov 07, 2007 | Rowenta Professional DE880 Iron
Euro-Pro Shark GI490 Iron Logo
158 people viewed this question
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
