Question about EA Sports Pelican Int'l. Colorado 15' 6" Canoe
How do I fix my badly faded canoe, colour is red and only faded down one side?
I bought a 12' coleman canoe that the previous owner painted. The paint is peeling badly on it, but not coming off easy. What would be the best way to remove the old paint? Thanks.
Posted on Aug 22, 2011
    Novelist:
  • 269 Answers
If you really want to paint it, try Tremclad. But you should not store it in direct UV light, because that is breaking down the plastic.
There are now paints designed to paint vinyl or other plastics. These will be more flexible than Tremclad (or equivalent) paints. Do consider whether the canoe is worth the time and money to do the job, or if you would rather be paddling it.
Posted on Jan 26, 2011
  • 76 Answers
I would recommend painting it with a type of paint that would adhere to the material the canoe is made of whether that is aluminum, fiberglass, etc. My guess is that you have been leaving only half of the canoe in the sun, so when you store the canoe, either keep it in a shaded area or cover it with a tarp to keep the sun off.
Posted on Aug 05, 2010
How to revive the color on old faded colman canoe vinal
That is fading in the plastic. So you could paint (use a paint designed for vinyl or other plastics which are very flexible) or just ignore it. I would not take the time.
May 12, 2014 | Boating
Dell 2135 fading left side when printing
It's possible that this could also be down to a toner cartridge inside the printer. I would recommend running off a copy of the colour laser test page found here.
The colour bars towards the bottom of the page separate cyan, magenta, yellow and black. Hopefully you will be able to notice that one colour is affected more than the others and replacing that colour may help.
Apologies if you have tried anything similar previously.
Oct 31, 2012 | Dell Office Equipment & Supplies
HP1600 colour fade on one side
it will most likley be the drum take it into a printer shop and they will clean it befor it gets to damaged as they are hard to replace
May 28, 2010 | HP LaserJet 1600 Printer
This printer has stopped printing reds and oranges correctly ? they are faded. Changed the toners & no difference
Print a "Config Report" from the printers menu...If u notice that the fourth square on the left side (fourth being the bottom square) for Magenta (reds and orange) is missing or very faded, this could indicate that the optical mirrors inside the printer have to be cleaned...Design flaw. ESP..if changing toners doesn't work and your your faded issue is with Magenta (Pink, red, or orange) colours are the only faded ones...With this design flaw in the optical mirrors, magenta mirror is the first to be affected!
Hope this helps!!!! I work in the industry :)
Feb 22, 2010 | HP Color LaserJet 2600n Printer
A picture of a fox for children to colour in please
moz-screenshot.pngmoz-screenshot-1.pngtry this site it has lots of free coloring sheets
http://www.coloring.ws/animals.html
Feb 16, 2010 | Fox Red Scene Painting Paddle Canoe...
Meyers snow plow doesent move left to right
i am thinking the celanoids went bad or a bad ground
Feb 28, 2009 | RTO Michicraft L-13 Canoe By Meyers
Faded red / pink on HP Color Laserjet 2605
you have to clean the image mirrors you can find a how to guide on hp's web site titled "fading red tones on color laserjet2600' process takes about 30mins to do.
Nov 11, 2008 | HP LaserJet 2605DTN Color Printer
Colours on TV Panasonic TX-32PL10 5/6 years old
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
Feb 11, 2008 | Televison & Video
Red Colour is faded....looks almost purple?
This might be caused by the CRT or by the chroma circuitry. You will need a schematic diagram and a multimeter set to read voltage. The first thing would be to look at the voltages on the CRT socket. With the TV on and the back off, using the schematic measure the voltages on the CRT socket and see if they match the schematic, if they do not (and they wont) find out if the Red Cathode voltage is too high of to low. If too high the red video circuitry might be at fault if too low the CRT might have a Cathode to grid short. In either case power down the TV and with determine if the CRT is bad (using a CRT Tester / Rejuvenator) Run a series of test acording to the instructions of the CRT Tester. This will tell you if the CRT is bad and if it is bad what problem it actually has. Then you may or may not have to rejuvenate the CRT (follow the instruction on the Tester / Rejuvenator) to do this. If the CRT is not bad then you will have to test the chroma video circuitry to see which component is causing the problem.
As you see you will need some equipment to do the job with. and you will have to have a little bit of an electronics background, If you do not have these I would suggest that you take the TV to a qualified TV repair shop for servicing.
I hope this helps,
Thank you,
Shuttle83
Oct 31, 2007 | Sony KV-36XBR450 36" TV
EA Sports Pelican Int'l. Colorado 15' 6" Canoe  Logo
714 people viewed this question
Top EA Sports Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an EA Sports Boating Expert? Answer questions, earn points and help others
