I would like to use the blower on my Amana 80 SSE gas furnace to circulate air through my house. I'm good with electricity and wonder if it is possible to install a simple switch to get power to the fan.
  • neil418 Jun 07, 2010
    it works! Thank you
    Novelist:
  • 117 Answers
Your thermostat should have a fan switch as most of them do. Simply switch the switch from fan auto to fan on and the indoor blower should run non-stop.
If your thermostat does not have this function, then the easiest and simplest way to do it would be to install a new thermostat with a fan switch. This would also be a good time to install a programmable thermostat and have better control over your comfort...
Changing the thermostat is quite easy. Shut off all the power to the furnace and AC and follow the directions with the new thermostat. Restore power, program the thermostat if needed and test it out. I recommend Honeywell thermostats...they are the most user friendly thermostats that I have found and don't fail as quickly as some of the other brands found at stores.
Posted on Jun 06, 2010
  • 1 more comment
  • neil418 Jun 06, 2010
    My current honeywell thermostat is a CT87N4450 with two controls. The left lever is Cool - Off - Heat and the right is Fan On - Auto.
    There are only two wires connected, The R & Rc connections on the thermostat are connected to the W contact on the furnace, and the W contact on the thermostat is connected to the R contact on the furnace. This was done by the installer, and appears to be backwards, but the furnace has been running fine like this for years. The cable has four wires, two of which are not in use.
    The contacts on the furnace are: Y W R G C
    The contacts on the thermostat are: R Rc O G W Y B
    Can you tell me the correct wiring to make the fan run independent of the heat, and what the thermostat settings should be please.
  • Bill Jun 06, 2010
    Here is some more information for you.
    The R terminal is for the 24V. The two R terminals should be wired together. The R and Rc should be jumpered.
    The W terminals are for the heat. The two W terminals need to be wired together.
    The G terminal is for the fan. The two G terminals need to be wired together.
    The Y terminal is for the Air Conditioner. The two Y terminals need to be wired together.
    The two common terminals need to be wired together as well.
  • Bill Jun 06, 2010
    Make sure that your B terminal on the thermostat is for a common. It typically is for the reversing valve in which case you will not have a common terminal and don't need to wire it up. But if you match the other 4 wire for wire and provide a jumper for the red at the thermostat, then you should be at factory wiring and ready to test it out.
    Again, ensure you turn off the breakers to the unit before switching the wiring. Failing to do so could blow a fuse or the transformer inside the unit.
Amana model ACS4250A (slide in). How do I remove the front panel?
[PDF]80-90 FURNACE SERVICE MANUAL.pdf - Johnstone Supply
johnstonesupply9.com/.../Amana/Gas%20Furnaces/GCCA%20Gas%20Fu...
Instructions. This manual is to be used by qualified HVAC technicians only. Amana .... Gas Furnace Upflow/Horizontal Induced Draft A Air Command 80 SSE.
Nov 06, 2015 | Kitchen Ranges
How do i reset power to thermostat from amana furnace is there a reset for controls?
The manual says it should automatically reset. However to manual reset the unit it says to "interrupt" the power supply. --which I think means unplug/turn off electric to unit for 20 seconds. If you do not have the manual go the manuf website and download it. --Also, this is a Goodman unit. If it does not reset something else it wrong that is preventing the unit from starting for safety reasons.
Sep 01, 2014 | Amana GMH81405DN 140,000 BTU 80% Gas...
Amana 80 sse flame rollout sensed what does this mean and how do I fix.
The flame rollout switch is located in the burner box on the left side on an upflow model. There are two wires connected to it .between the two connections is a small red button. Depress this until you here a small click. This should reset the switch. These
switches usually open because the flame is "rolling" back instead of being drawn into the furnace.start furnace and check for flame rollout.when the main blower fan comes on if you notice any change in the flame turn furnace off and call a qualified service person as this could indicate a cracked heat exchanger and could cause carbon monoxide to enter the house a potentially dangerous situation. I strongly urge anyone with a gas appliance installed to have a good carbon monoxide(CO) detector installed also. Hope this helps.
Dec 10, 2013 | Heating & Cooling
Amana 80 sse
Amana aircondition window unit wouldnt turn on. E2 indicator light was on. I turned off breakers and turned them back on as suggested for an Amana furnace. Yay, it works now. Thank you.
Jan 19, 2012 | Amana Heating & Cooling
Amana Air Command 80 SSE gas furnace will not stay running
In the path of the flame on the last burner that starts, there will be a small rod. That rod is the flame sensor. Take a scrub pad and polish it. Also check the electrical connection that goes back to the circuit board. Disconnect any ground wire from the circuit board to furnace cabinet, sand it and replace it.
Mar 14, 2010 | Heating & Cooling
Amana gas furnace,air command 80 sv. does not ignite blows cold
Hi check out the pressure switch jump it out and see if it lights also check the igntion coil is glowing
Feb 09, 2010 | Heating & Cooling
My amana 80 sse furnace will not heat. looks like furnace light is off. what can i do to reset it. thanks
Turn off breaker. Turn it back on. If furnace is completely dead still, change your transformer. It's cheap..
Dec 11, 2008 | Heating & Cooling
Need to know what size Blower motor I need for and Amana SSE 80 furnace.
The blower size is selected based on the details of your home. The size of the motor must match the tonnage of the A/C. The tonnage of the A/C will be determined with a heat gain/loss calculation.I believe there are at least 2 options for this furnace 3 Ton, and 4Ton.
Jul 02, 2008 | Amana Heating & Cooling
Furnace manual
here's the link for your problem and I hope that it helpshttp://johnstonesupply9.com/TechDocs/Amana/Gas%20Furnaces/GCIC%20Gas%20Furnace/GUIC%20GCIC%20TECH%20INFO.pdf Thanks for unis FixYa!
May 26, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
