Question about Jura Capresso C1000 Espresso & Coffee Maker
Jura capresso E8
Nothing will come out the spouts. Water is in the holder. water and coffee grounds end up in tray
    New Friend:
Sounds like your spouts are clogged with fine ground. try cleaning them out (use a needle to carefully open the spout passage) and make your grinder setting a little more coarse.
Posted on Oct 13, 2013
    Problem Solver:
  • 4 Answers
Pull out drawer clean and wipe out then spray pam
Posted on Jun 15, 2013
  • Tom Sullivan
    Tom Sullivan Jun 15, 2013
    Remove drawer wipe out grounds then spray pam
  • 123 Answers
Did it work before this?
Sometimes hard water can build up and cause blockages.
Try mixing hot water and white vinegar (50/50 mix) and try running it through the machine. If this works, run it through a few more times than run cold water through a couple times to get rid of the vinegar.
Good Luck.
Posted on Apr 10, 2008
Drawer will not go back in for Jura Capresso impressa
For Jura F7 Series, "Tray Missing, can't put it back in". With a small flashlight, look in to the cavity which the tray and grounds container reside in. Along the right side above a slot to the end, you'll see a white micro switch. with a "Tooth Pick" simply press the switch inward (to the right) and hold till the machine cycles the Levcer / Flap up and out of the way.! Put your tray and grounds container back in and begin brewing!! -dh
Mar 17, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capressa -Tray will not go in, looks like something from above protruding down in the back so that the tray sticks out 1/2 inch (so machine does not work)
I had the same issue. Had to send mine in for repair. Cost $235.00. Nothing I did would fix the issue. They said there was a major blockage. They cleaned it and sent it back. They also fixed my issue with water leaking from the frother.
Nov 08, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
I cannot get the drawer to close completely on my Jura E8 in order for the "missing drawer" light to go off. I've unplugged the unit to allow chip to reset... nothing. I think the elevator is...
I have the same machine and this seems to happen if the grounds bin is pulled out before it goes through a full cycle. take both the grounds and water trays out. Try to fit the grounds bin around the "elevator", slide the grounds tray underneath that then the water tray as well. It should slide right in then the machine will complete the cycle and work just fine :)
Feb 06, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
Cannot install tray with ground basket installed, after removing. Mechanism is blocking the ground basket when the tray is slid back into the unit after emptying.
Try putting a container under the coffee spouts and pressing the rinse button. This will usually free any coffee grounds that may not have been expelled into the grounds basket from the last time the machine was used. The grounds can get stuck and block the slide path of the grounds basket.
Dec 23, 2010 | Jura Capresso Jura / Capresso IMPRESSA J5...
One spout is very slow with leaking
The spout is only a plastic with two holes, if the one is only leaking while the other is running corectly then you only need to clean it with hot water and a small brush the hole and the groove. the spoot can easily removed, or even emese it in a pot with hot water for 20 minutes then flash only water.
Jan 05, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Both spouts seem clogged
I have a Jura Impressa F7 that had the exact same issue. To solve it was pretty simple. Try and make a cup of coffee, and while the machine is trying to pump the coffee thru the spouts, grab the chrome handle on the spout and vigerously move it up and down rapidly. You should notice small grounds of coffee dislodge and follow the stream of coffee into your cup. If you do this a couple of times, you will be able to clear the trapped grounds within the spout. Hope it works for you as well as it worked for me.
Jun 23, 2009 | Jura Capresso Impressa F9 Espresso Machine
Jura capresso z5 not working
Call Nick or Anthony at Style Cafe on 0844 2279229 they have a wealth of knowledge on these machines and can Service them if required
Jun 11, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
No coffee will dispenses
I would remove the coffee spout and check the lines into it. The coffee seems to stop when it hits the spout and goes through the by pass instead. Remove the spout(be careful) then run a coffee and see if it works.
May 24, 2009 | Jura Capresso Impressa E75 Espresso &...
Jura Impresso E9 not dripping through spouts but into drip tray
This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
Feb 05, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Jura Capresso C1000 Espresso & Coffee Maker Logo
896 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
