Question about Hotpoint HSS25GFP Side by Side Refrigerator
I have water comming out of the freezer at times and a pool below the bottom shelf.
  • Deafened Jul 26, 2010
    My GE Hotpoint frig is making a low grinding noise all the time. It sounds like it might be a water pump that never shuts off. It is also making ice until the freezer door pops open and I have to empty the ice bin. Can I do something about this myself or do a need a service call? Sound is driving me crazy. Husband can't hear it. Thanks, Diana
  • 54 Answers
You drain has frozen up probably because of a clog. Take the bottom door out and right at the rear bottom of the freezer back in the middle you sill see a drain. When the freezer goes in deefrost the frost will melt on the evaporaterr lines and must go down under the freezer yours does not and when the freezer comes on that water freezes. next time it defrost it heats that ice and the melted water come out the front of he door. clean that drain.
Posted on Jun 06, 2010
Water pooling on top shelf in refrigerator with top freezer
Your drain is obstructed within the freezer compartment causing the water to floe into to lower section via vent ducts. To correct this, you will need to access the rear wall of the freezer and at the bottom you will find the drain hole. Remove the obstruction with warm water and remove all the ice also.
Good Luck
Mar 06, 2016 | Refrigerators
Water pooling at bottom, how do I find out why?
Water is pooling at the bottom of your refrigerator because the drain in the freezer is clogged, probably with ice. You need to turn of the refrigerator and empty the freezer. Remove the cover in the bottom of the freezer by first removing the back cover of the freezer and then the bottom cover. You will probably see it full of ice. Remove this ice by chipping, or if you have time, let it thaw. Then, located the drain in the back of the compartment below the coils, and thaw it. You can use a hair dryer for this. Eventually, you will see the water drain, and you can dry everything up and put it back together. You should have no more problems. If you do, then you need to look at testing the defroster.
Oct 05, 2015 | Maytag Refrigerators
What causes water to pool on the top shelf?
Hello
It is caused by a clogged defrost drain in the freezer compartment of your refrigerator
To fix this you will need to empty your refrigerator and unplug it.
Remove the back panel of the freezer and look under the cooling coil, you will see a frozen drain
pour hot water on the drain hole until water flows freely through the drain to the bottom pan..
That's it
Jun 04, 2015 | Frigidaire FRT21H8 Top Freezer...
How to tell the model number
Is it coming out under the vegetable drawer? We just had a problem with water dripping down into the freezer. Check the drain at the lower back left of the refrigerator, above the bottom shelf to see if it is plugged. Water will be pooling there. If it is, use a turkey baster and warm water to flush it out.
I never found the serial number for our unit but used the model number from the manual.
Nov 23, 2013 | Liebherr KIKNV3056 Bottom Freezer...
The top of the inside of my 2002 Whirlpool refrigerator Model ET1FTK (top mount)is frozen and is dripping onto the first shelf.
The cause of that drip is going to be a blocked defrost drain in the freezer and the water from the defrost is pooling up in the freezer then when it can't hold anymore it's dripping through the vent in the ceiling of the refrigerator onto the shelfs. By removing the back wall of the freezer you could find the drain on the bottom of the freezer coil. By GENTLY peircing that frozen drain at a 45 degree angle until a small hole is formed in the built up ice it could be totally flushed using warm water once a small opening is made in the ice in the drain.
GENE
Oct 13, 2011 | Refrigerators
Ice and water on the bottom shelf of my sears Kenmore regular refrigerator. things are cold but water pooling on the bottom shelf.it is a Kenmore freezer on top and refrigerator on the bottom
Drain stopped up. Defrosting occurs and condensation water must be evacuated, this is done through a dran hole. Clogged drain means water inside under crispers messy all that luv. Find the drain hole and give her a good old clean out. All will be good.
Jan 18, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Jun 17, 2009 | Refrigerators
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Water pooling on the bottom shelf of the freezerless refrigerator
take back panel off inside freezer.
you will see a drain tray at the bottom with a drain hole in the middle. this hole is blocked with ice
melt off with a hairdryer and follow up with hot water till water flows away freely.
check drain tray heater is ok as well
Oct 11, 2008 | Kenmore 16.7 cu. ft. Freezerless...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
174 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
