2000 Ford Taurus Logo
Posted on Jun 06, 2010
Bright lights arent not working, all my other lights work, and low headlamps are working but when i switch to my brights, the headlights turn off. is this a fuse? or could it be the bulbs? let me know people,,,,, thanks
Lee M
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 25, 2016
Lee M
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
645
Points
The dimmer has nothing to do with the headlights. I have a Ford focus too and I've heard it's a fuse. Here's hoping because I'm having the same issue.
Anonymous
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Jun 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
11547
Points
69
It's your dimmer switch.
2answers
Why won't headlights come on 2007 Chevy uplander
The headlights of your Chevrolet Uplander could be on. If the lights are out you may have had a headlight bulb fail. The headlights are located on either side of your licence plate and usually have a bright light on them indicating which side is forward.
98 corvette headlights not working
If you can verify current going out of the main dash switch towards the headlamps, then I would go relay hunting. My guess is the switch, since the brights and fog lamps work on demand (dimmer switch pulled).
2answers
My 2003 Chevrolet Impala has a problem with the headlights. bright lights work dim lights do not work. the light bulbs seem to be fine.
If you are 100% sure the lights are ok, it's going to either be the headlamp relay or the high/low switch. I'd swap a bulb for a new one before moving on to more troubleshooting.
Hope this helps.
The headlight when i put them on low beam they do noit want to work but the long do
either the bright dim switch or the headlamp switch is bad .dimmer switch is the easiest to check with a test light or volt meter
1997 Mercury villager left headlight doesn't work.
go here. we can help you. Also, did you check the headlamp relay in the box under the hood? One relay is in box in front of battery, other is in narrow box along passenger side fender under the hood. swap left & rt headlamp relays to see if it changes.
http://groups.yahoo.com/group/villagerquest/
1helpful
Only brights work, dimly lit headlamps, no fog lamps
Recheck the bulb number. This happens when the wrong bulb number is installed. Otherwise it could be a bad headlight ground.
99 nissan sentra headlamp - hi beam low beam issues
could be the switch. did you do anything to the switch when you changedheadlamps? maybe you put the lamp in incorrectly also did the brights work on the lamp that was "burned out"?
2answers
I have a 2002 buick century. The running lights will come on but the headlights will not come on. What do you think?
I have a 2000 Buick Century and if you hold the switch the brights will work but the low beams will not work not a bulb issue. The turn signals will work but still no head lights
Headlamps for a 2006 gmc sierra aren' t working
i would try replacing headlight switch....
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
