Question about Kenmore 23822 Top Load Washer
Code 06 I have a Kenmore Elite Washer. A code 06 is continue to come up what is that code
  • 5,081 Answers
In the manual for a Kenmore washer the instruction for an F06 code (electrical problem) is :
Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN/SPIN if there is excessive water in the washer. Re-select cycle and press START.
After that, you might try unplugging then plugging it in again.
Posted on Jun 06, 2010
  • INDIRA KUMAR
    INDIRA KUMAR Jun 06, 2010
    The F06 error code indicates a drive motor tachometer error. This error is
    virtually impossible to accurately diagnose if it is intermittent and
    not occurring when a technician is present. The most suspect components
    that would cause this failure code are the drive motor, the motor control
    unit (control board) or the wire harness. In some instances, this could
    be caused by severely overloading the washer so that it cannot spin
    properly.
    Make sure that the washer is not overloaded. Another problem
    that could cause the error code to be displayed intermittently would be a
    loose wire harness connection that is affected by vibration when the washer
    is spinning at high speed. I anticipate that the technician likely
    checked the wire harness connections between the drive motor, the motor
    control unit and the central control unit (main control board).
    Although in some instances this error code could be caused by a
    failed central control unit, this would be rare. I am not aware of the
    F06 code
    being caused by a problem with the user interface control board. This
    information may help you more clearly understand the failure in the washer.
How to fix kenmore elite washer 110.270.32603 that continuously shows F1 error code?
I had to call Sears and they sent a technician out. He ordered a new part and it fixed it. Haven't had issues in over a year now.
Jun 12, 2014 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 model 110 f-06 code comes on and washer stops .
I was getting a F-xx code can not remember the number.
If you remove the bottom front plate , I remember 3 three screws.Behind that is the filter for the machine, mine had a 2-3" white cap that came off with a screen inside that was plugged. When you open it up you can get a fair amount of water come out. The machine will not work until you put the front cover back on.
UNPLUG the machine FIRTS
Aug 23, 2012 | Kenmore Washing Machines
What is 06 code on a calypso washer
could this be an OB code? if so it is an off balance code meaning the wash load is to unbalanced.open the lid redistribute the load and start it back up. all of the manuals for the calypso do not show any numbers or an 06
Nov 15, 2011 | Kenmore Elite 45986 Front Load Washer
Servise code f 06
"F06" is a Motor Speed error code. The following link explains how to troubleshoot:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Read through the link provided and verify all your wiring and connections, first. Sometimes the problem is as simple as a loose plug. Make sure resistance checks are done with the washer unplugged. If you have any questions, please let me know. I hope this helps you.
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite HE 3 displays F 06 code
F 06 cose for faulty motor controller. reomove lower acess panel adn ck for good wire connections (board is in rt front corner) check wiring harness to lower control board,. sometimes a glitch( it is a computer after all). try unplugging unit fro 2 min . if not replace motor control board
Mar 04, 2008 | Kenmore Elite 45986 Front Load Washer
My kenmore elite smartwash/he4t (error code)
Try shutting off the machine. Switch off Usually the door opens in 2 minutes or so. Do not force open the door. There may be instructions in your book to open the door manually. It could mean unscrewing somewhere.
Apr 04, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 23822 Top Load Washer Logo
116 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
