Question about Zodiac Duo Clear System Chlorine Generator
My duoclear salt generator is not working no lights no power reset is fine is this my circuit board
3 Suggested Answers
SOURCE: ZODIAC DUOCLEAR 25K DOESN'T FUCTIONING WELL
I have the zodiac duoclear system and have used it for nearly two years. All in all, it's a very good system. I have had similiar issues on occassion. Have you tried the master reset button on the lower right hand face of the control board? I've been able to clear up the lights by resetting the system.
If the salt content in the pool is not correct, the system will not allow you to superchlorinate. Your salt level should be at 4000 ppm. The add salt light is programmed to come on if the system gets below 3600 ppm. When the system is below 4000 ppm, it is unable to generate the chlorine needed. The lower the salt, the less you can chlorinate. Might not be your problem, but I've run into this before too.
The lights for replacing your cartridge puzzle me. I'm making an assumption that your pool is probably dirty if you're trying to superchlorinate. The dirtier the water, the faster the electrode in the cartridge will get covered in scale from the current and conversion process. Try cleaning the new cartridge by placing it in a bucket with a 75% water and 25% muratic acid mix. Let it soak for a few minutes and gently swirl it around in the mixture. This will clean the contacts in the cartridge.
Keys with the Duoclear system: Salt content and clean the filters regularly. Don't know if this will solve your problem or not, but good luck.
Posted on Jan 26, 2009
SOURCE: DuoClear 20 can't get salt light to go out unless
I have a Duoclear 25 for 3 years now. The unit has been nothing but trouble. I too have a low salt light even when the pool is tested at 4500ppm. 4500ppm for our taste is too high. The main board has been replaced for erroneous errors and now one year later the salt cell generator is non functional. The quality is poor. Furthermore most pool stores don't even know how the nature 2 works and alwasy recommend chemicals that are harmful. The company Clearwater has poor customer service.
Posted on Apr 26, 2010
How can I reset my circu-pool salt generator? it is giving me a high salt light and a check cell light
I have a Circu-pool SJ45, no issues . Have you cleaned the cell. How old is unit. Have you checked pool salt level. Have not seen reset button, will look .
May 15, 2016 | CircuPool Swimming Pool Salt Water...
When you tourn on the super chlorinate button, does it turn itself off?
To properly start up the system, add the salt, let circulate for 6 hrs then turn on the generator. running with extremely low salt can damage the unit. you will need a minimum salt reading of 4000 ppm with the duoclear.
when you activate the superchlorinate feature, the electrode will run at 100% for 24 hrs and then revert to the regular programmed level.
Jun 19, 2014 | Zodiac Duo Clear System Chlorine...
Cannot get zodiac duoclear salt cell out flap
possible cell overheating and distorted plastic housing might have to replace
Jan 04, 2012 | Zodiac Duo Clear System Chlorine...
All lights are on and everything appears fine but the unit does not appear to be producing chlorine. Have had unit on for two weeks but testing shows no chlorine . Salt level is fine and unit is only in...
I am not an expert on the Duoclear but I have had mine for 5 years and have not had any problems. This unit and all salt water systems will not generate chlorine when the water temperature is below 65 degrees f. I am not saying that this is why yours is not generating chlorine, just commenting in case you were unaware.
May 25, 2010 | Zodiac Duo Clear System Chlorine...
Aug 25, 2009 | Zodiac Duo Clear System Chlorine...
DuoClear 25 doesn't chlorinate well, chlorine output lights
have water checked see if chlorine is locked that will act like chlorinator not working also crack output union so water drips out test with strip if chlorine oxidize water if no chlorine unit not working
Jun 12, 2009 | Zodiac Duo Clear System Chlorine...
Dec 30, 2008 | Zodiac Duo Clear System Chlorine...
Zodiac Duo Clear System  Chlorine Generator Logo
132 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
