Question about HP LaserJet 2840 Printer
1. Printer will not print. 2. Error codes says, " replace supplies" 3. Replaced black toner which is the only one i am using but that did not fix problem. 4. need to reset or delete error code.
  • jm10330 Jun 06, 2010
    1. Need to reset "replace supplies" error button. Please be advised, it is NOT the toner. Thanks
There is something wrong with your drum. First try to replace a new chip for the drum and make sure that the chip is working. If that does not work then check to see if there is any damage in your drum. If you find damage then replace it with a new drum
http://www.fixyourownprinter.com/forums/laser/51838
Posted on Jun 06, 2010
  • 560 Answers
Hi. Please check your color toner. The printer will not print if one of your ink is empty even if you are not using it.
  • 3 more comments
    that is not the problem. I have seen many people post this same problem stating their toner was fine. There is some other kind of error. Please look into this or check with someone else whom is familiar with this printer. thank you.
  • Liza Halbrook
    Liza Halbrook Jun 06, 2010
    Currently, we have no way of bypassing the color toner requirement even if we are printing in black only. If you have been printing in black only but did not choose to print in "grayscale", your color toners were used to print pictures/graphics or gray shaded text and it is more likely that one of your color toner is empty.
  • Liza Halbrook
    So none of your color toner is empty?
    Again, as stated, that is not the problem. Please check with someone else.
    Color toner has been out for months. That is NOT the problem. MANY people have posted the problem stating that ALL their toner is new. Color toner went out while under warranty and the HP Tech guided me through changing all the settings so that it would still work. if you don't know about this problem, maybe someone else in your department does. let's not spend time troubleshooting something that we know is not the problem.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
How can I solve the problem in Konica Minolta Bizhub 282 error code C4101
You have Print Head Failure, the Print Head houses the LASER along with the LASER is a motor, your code deals with the motor, Motor can not be replaced, entire unit is, try this site they mite have it or will have to get a Konica Minolta Dealer, Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 23, 2013 | Genuine Konica Minolta Genuine Bizhub...
Replaced fuser and toner units now only prints black pages
Printing on a laser printer has 3 steps:
1. electro-statically charging the "drum", at various tiny "pixels",
to identify where the toner-powder should be placed.
2. feeding toner-powder onto the charged drum.
3. making the fuser produce heat to "bake" the ink onto the printer.
So, a failing unit or failing electronics would "charge" *ALL* of the drum,
thus putting black ink EVERYWHERE onto the page.
Take the printer to a qualified technician.
Nov 13, 2009 | Epson EPL-N3000 Laser Printer
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
HP 2840 *(Error Message) = replace supply using black only Will only print in black All color and black toner are 75% or more full The drum was low so I replaced it just in case but error message remains.
By repalce supplies, it means that you have to replace the other toner cartridges and that it is only going to print black only
Al
Eliteprintersolutions@gmail.com
Apr 14, 2009 | HP LaserJet 2840 Printer
Oki Printer c3200 error code
Suggest you order a black drum, which may include a black cartridge. Replacing BOTH the cartridge and the drum should solve the sensor problem, then you can swap parts to isolate where the problem is.
May 27, 2017 | OKI C3200n Led Printer
HP lasrjet 4240n it won't print
The printer is unable to read the electronic information (e-label) on the print cartridge so that the printer can keep track of the page count for the print cartridge.
1.
Open the top cover, remove
the print cartridge, and
reinstall it.
2. Install a new HP print
cartridge.
3. Check the connection
between the
DC controller PCA
(location J97) and the
memory chip on the print
cartridge (location J600).
4. Replace the memory chip
cable and contact assembly.
5. Replace the
DC controller PCA.
Sep 03, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
My printer is not printing
My printer at work kept saying it was low on black toner. I finally replaced when I got the message Black toner supply error. I gave it a minute or two to adjust itself and when that didn't work, I turned off for about ten seconds and then restarted it. I've only had two problems with this printer and I have had to turn it off both times before it would work perfectly, if that helps anyone.
Nov 05, 2007 | Samsung CLX 3160fn All-In-One Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
HP LaserJet 2840 Printer Logo
158 people viewed this question
Seeker5211
Seeker5211
