Question about Dishwashers
Dishwasher error says there is too much inlet water/overfilled, but this does not seem to be the real problem. Wont move on in programme. Nothing is blocked, checked all of that
SOURCE: BOSCH SPS5462GB/19 No water seems to
Found the problem after stripping down around the main pump area.
The air pipe connected to the pressure switch on the front right hand side is connected to a small plastic box which in turn is connected to the flow pipe that fills the machine,and the box was completely blocked with slug which stopped the pressure switch from operating and so prevented the water input solenoid from opening. Hence no water would come into the machine
Posted on Sep 09, 2008
SOURCE: Bosch builtin 60cm SGV4313 dishwasher
many thanks however intend purchasing new machine
Posted on Sep 15, 2008
  • 9 Answers
SOURCE: KitchenAid KUDP02 built-in dishwasher will not fill with water
Couple of things that come to mind here... May be helpful or not - but after all this is free ifo and probably worth what you are paying!!!
Anyway:
1: Have you tried removing power from the appliance?? All these modern appliances use a microprocessor and - like MS WINDOWS - need a kick up the bum now and then - (Well.. with Windows it seems to be every day- hour -minute - or so)
2: Dishwashers are installed with water reduction valves, so there could be a problem with one of there (particularly the hot water side).
3: The water inlet is controlled by soleniod valves (read: electronic valves). If the valves are not opening, no water will enter the appliance, so there could be a problem with the valves.
Posted on Jan 16, 2009
  • 236 Answers
SOURCE: Faulty dishwasher.
several poss faults tap turned on? if so probably the unit needs to have the meter tank and feed piping cleaned out. if this is all clean then it could be either the water valve is faulty or you have a leak into the base and the unit will not fill up when it is in "flood mode". (check this out by tipping machine to the side and see if any water pours from the base).
Posted on Mar 18, 2009
rylee_smith
  • 8619 Answers
SOURCE: it doesn't start and clean light flashes
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 07, 2010
Testimonial: "You solved the problem quickly and easily. Thank you for the great assistance!"
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
Why does it stop running after two mins and has an error code of OE?
The OE or Overflow Error code.
The water inlet valve is an electrically-controlled valve that opens to allow water to enter the dishwasher. Depending on the model, the valve stays open either for a set length of time or until the dishwasher has enough water. However, if the water inlet valve doesn't shut off after the dishwasher has enough water, the dishwasher will overflow. If water drips into the dishwasher when the door is open, or if water collects at the bottom of the dishwasher while it is not use, you may need to replace the water inlet valve.
Feb 13, 2016 | LG LDF6810ST Stainless Steel Built-in...
I have a adg7560/1. the cycle starts but ends after a few minutes. the light flashes four times
Run the dishwasher through a test mode
Test Mode
Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
Open the door and set the program to the first program. (Normally rinse).
Turn the power off.
Press and hold the start button and while holding turn the power on.
After a little while the start button will flash, release the button.
Press the start button once and close the dishwasher door.
The machine will now run through a diagnostic routine.
Should take about 20 mins.
The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the programme.
To exit diagnostics at any time just press and hold the start button till the programme is cancelled
Error codes
F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
FB. 12 Flashes. Motorised Diverter Valve
FC. 13 Flashes. Water Hardness Sensor Failure
A fault with no fault code indication = faulty module
Read more: http://www.diynot.com/forums/viewtopic.php?t=200838#ixzz2zKhYFHxt
Apr 19, 2014 | Whirlpool Dishwashers
Does not fill with water.
follow this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 08, 2013 | Thermador 24 in. DWHD64CS Stainless Steel...
Today, dishwasher started overfilling, and spilling water onto the floor. We turned off the water supply and let the dishwasher finish its cycle, turned on the water, started another cycle and it began to...
Hi
Thanks for using FixYa. If the dishwasher is overfilling it’s caused because of water-inlet valve going bad. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Whirlpool 24 in. DU920PW Built-In...
Hi,\r\n
yes you need to reset dishwasher to time fill.turn off the power button wait 10 sec,push and hold the programme and start buttons then turn power back on.hold buttons down until display lights up then release them.press programe button until 4 shows in display,then press start.test dishwasher. F4 is an inlet fault.
Jun 07, 2010 | Asko 24 in. D3350 Dishwasher
IE input error on LG dishwasher Model LDF6810ST
Chris;
The float you speak of is located behind the left side panel. (be careful if you remove the panel, the back edge is real sharp,.... I left a pint of blood at one house !) Water enters the dishwasher fill assembly and turns a paddle wheel, which allows the control to count the revolutions, determining the amount of water filling into the dishwasher. The float is inside a chamber in front of (and attached to) that water guide and it has two micro switches at the top of the float chamber. If I recall correctly, the float is only for overfill protection, as the paddle wheel determines water amount. You should check the screen at the water valve to make sure nothing is obstructing inlet valve water flow. Also, make sure you are not using a "flood safe" inlet hose, which are designed to shut off water if a hose breaks (but can cause water supply issues). You may have a bad control board or wiring connection. On a new unit I would suggest calling for warranty service.
Please don't rate this solution, as anything but a FixYa will lower my score.
Thanks, Carl.
Nov 20, 2008 | LG LDF6810 Built-in Dishwasher
Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
May 21, 2008 | Dishwashers
Dishwashers Logo
906 people viewed this question
Top Dishwashers Experts
