Question about Tomtom ONE 3rd Edition GPS
It won't turn on
It has been sitting in the car without use for a while. now it won't turn on.
    Problem Solver:
  • 17 Answers
Have you tried charging it for a couple of hours? If you did not use the tomtom for quite some time, the internal battery will discharge. Try charging it for a couple of hours by using a wall-charger or use the usb to pc cable.
Does the green light turn on (indicating its charging)?
If this all doesn't help, you should contact tomtom service center. A local number can be found here: http://support.tomtom.com/
Take care!
Posted on Jun 06, 2010
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 28 Answers
The Tom Tom One GPS discharges on its own when off, so if you leave it for a while it'll drain down the battery and won't turn on until you recharge it.
You can avoid this in the future by resetting
the unit, so it doesn't continually drain the battery when off.
See more details here-
http://www.fixya.com/support/r5200725-tomtom_gps_battery_discharge_when_off
Posted on Feb 19, 2011
2004 Ford Explorer won't start if I let it sit for a a few days. I turn the key and it just clicks but will start with a boost. I have had the battery and starter checked and the mechanic couldn&#
Why didn't the mechanic continue on & resolve the issue?
You don't have the experience to do so, as your here
No one can tell you what is wrong without the vehicle to test,
common sense
Feb 07, 2013 | 2004 Ford Explorer
Car sitting for a year, turn over but won't start
CLEAN & DRY ALL PARTS CHECK FUEL IS GOOD,ONLY IF YOU KNOW WHAT YOU ARE DOING PLACCE SOME FUEL IN CARB ,CLEAN & CHECK PLUG GAPS,A CAR STANDING WILL LOOSE THE PETROL ORIGINAL STRRNGTH
Oct 04, 2012 | 1997 Buick LeSabre
Car sitting for a year, will turn over but won't start.
the fuel will be contaminated try putting some fresh in the carb clean all the ignition electrics just cause its turning does not mean it will fire,clean the plugs remove air filter,(just till the car starts) then replace service the car its a must
My car has been sitting for 2 years and won't start. The engine turns over but it sounds like not getting gas. I read somewhere to spray gas starting inside air intake valve. Where is the air intake v
Safer is to use 'carburetor cleaner' which is also flammable but a little less dangerous than using gasoline.After sitting a long time, our modern gasoline gets tired; never allow something to sit so long without adding some 'fuel stabilizer.'If possible with your car, I would drain (siphon) the tired gas out and replace it with a few gallons of fresh.
Really tough starting problems can also be overcome with 'starting fluid' which is pure ether and very flammable.Any of these may require the removal of the engine air filter so the liquid gets into the intake manifold.
Stale gasoline can also gum up the fuel injectors which may have to be removed for service if none of the fluids causes the engine to fire.
Nov 23, 2011 | 2005 Jaguar S-Type
Car has been sitting; will turn over but won't start. Used starting fluid and car starts but quits. Won't fire without starting fluid. There is fuel in the tank. Help!!
My first thought is to check the fuel pump operation.
Check to see if fuel pump is getting power.
This is how I check the pump.
Usually there is an in-line fuel filter that can be removed.
While its removed...bump the starter to see if gas shoots out the gas line.
If not, there might be a clog at the pump...or the pump needs replacing.
Hope this helps...
Jul 24, 2011 | 1989 Oldsmobile Delta 88
I have a 1999 gmc sierra with (as of 30 days ago cat. converter, fuel pump and filter, cap and rotor) changed in garage. regular oil changes, tune ups as of 8 mths. it has lots of cranking power, but...
If i understand you right the truck has been sitting for two years.If it has been sitting that long without running or moving the gas has turned to varnish...I suggest that you drain and refill the fuel tank,and replace the fuel filter located on/in the frame rail on drivers side.
Jun 18, 2011 | 1999 GMC Sierra
94 vette won't start,bat good,have org. key,fuses ok,high beam light on lights off,lcd cluster won't light up?
Disconect the battery and ECM for FOUR DAYS then reconect the ECM and BATTERY. Let it sit for another four days without turning anything on. It should start but will run rough for about 200 miles as the ECM relearns the system. I had the same issue and that is what fixed it.
May 14, 2009 | 1994 Chevrolet Corvette
Tomtom ONE 3rd Edition GPS Logo
589 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
