Question about Quinny Buzz 3 Sulphur Jogger
Puncture back wheel
I have a puncture of one of the rear wheels of my Quinny pushchair. I have no idea how to get the wheel off let alone fix the puncture. Is there somewhere I can take it to get it repaired?
  • 3 Answers
You take the wheel off by pushing in a button at the side of the wheel on the inside, it is a quick release wheel and it simply clicks back in when it's been repaired. hope this helps!!
Posted on Jun 06, 2010
The procedure for removing the rear wheel from my Trek Navigator 200 to repair a puncture or replace the inner tube. Regards Paul emson
Try any Search Engine for "removing the rear wheel " and "repair a puncture"
The internet has most answers immediately and some with video.
Aug 08, 2011 | Trek Navigator 200
I have a bebecar ip op and i want to know how to detach the rear wheel as it has a puncture?
The rear wheel is held in place by a locking clip which is controlled by a lever. To remove the wheel, simply press the lever rearwards, and pull the wheel away from the housing. Remove the tyre carefully, using appropriate tyre levers, in order to repair the puncture in the inner-tube, or to replace it.
Mar 27, 2011 | Bebecar M City Stroller
Need to replace back tyre of quinny pushchair as is punctured. Live in east grinstead. Where can I get a replacement.
I trust you mean East Grinstead, UK. Parts for the Quinny stroller can be ordered from the following location, a distributor in the United Kingdom:
Dorel U.K.
Hertsmere House
Shenley Road
Borehamwood, Hertfordshire WD6 1TE
Tel. (020) 8 236 0707
Fax. (020) 8 236 0770 I recommend you order 4 new wheels that are solid and do not require air. That way you will not have to worry about the tires getting punctured. These wheels are typically an OEM part and should be ordered through a distributor to get the proper size and fit. You can get more information regarding models, options, and accessories at www.quinny.com. Hope this helps.
Nov 21, 2010 | Health & Beauty
How to remove rear wheel to have puncture repaired please.
  1. Turn fuel tap off.
  2. Remove both side panels.
  3. Lay scooter on engine side ( on some kind of blanket or mat to protect the bodywork. don't forget handlebars and front mudguard.)
  4. Remove the 5 nuts holding the wheel to the hub with a 13mm socket. (make sure you remove the hub nuts and NOT the 5 which hold the two halves of the wheel itself.)
  5. Slide and wiggle wheel out past the exhaust.
  6. Do the above in reverse when puncture fixed.
Sep 25, 2010 | Peg Perego Vespa Scooter
Back wheels keep deflating
hi, the chances are you have a puncture os something sharp sticking into the inner tube inside the tyre, what you need to do is buy a puncture repair kit then using the repair kit you take the tyre off the wheel then take the inner tube out.
now blow the inner tube up and place it in bowl of water and you should see bubbles coming off the inner tube, mark this with pen when dry so you know where the whole is, now use the puncture kit and place a patch over the whole, you can buy glue type patches or stick on patches without glue, you peel the back off the patch and put glue on or stick it over the whole if its a stick on patch and not glue.
then whilst this dry run your fingers around the inside of the tyre and check for any thorns or something sharp sticking in the tyre if you feel anything remove it and you should be ok, then when glue dry put the inner tube back in tyre and fit the tyre back on wheel now when you pump it up it shouldnt go back down unless you get another puncture.
if you are unsure what you are doing then taking your stroller into any bike shop and ask them to repair the punctures for you and they will do this for you whilst you wait.
Jul 10, 2010 | Quinny Buzz Three Wheel Stroller
An you get hard rear wheels for the quinny buzz 3
No sorry but you can get new inner tubes very cheaply off ebay & something called gludge(i think thats what it is called) anyway all bike shops sell it so does ebay, you can buy it to put inside tyre so you won't get a punture or a spray which you put inside inner tube it seals it right away if you get a puncture . it is easy to do I did it myself.
Jan 17, 2010 | Quinny Buzz Jogger
My quinny rear tyre is flat tried to inflate the tyre but still does not work what should i look out for
you have a few choices
but if you want a long term fix you are better off getting a new inner tube as once a puncture occurs with the quinny wheels they will carry on doing it but theey are cheap enough to replace via ebay for about £6
if you dont want to replace you will need to remove the rubber wheel from the hub as you would a bike tyre then remove the inner tube
pump the tyre up put in water so you can find the hole then fix with a puncture repair kit
if you want to carry on using you can fill the tyres with tyre weld as you would a car they dont puncture and makes the quinny a smother ride
and if all else fails you can buy a used or new pair of wheels from ebay between £15 and £30
hope this helps x
Dec 14, 2009 | Quinny Buzz Three Wheel Stroller
I took front wheel off bike to fix puncture. i
Loosen up the hub nuts. Center the wheel between brake pads. Put something like a screw driver in the space between wheel and frame to keep the wheel centered and not moving as you tighten the nuts.
Oct 02, 2009 | Cycling
Quinny pushchair puncture
A tire can be repaired with a regular bicycle repair patch. Otherwise you can use inflate a flat or tire slime to seal the leak, but you will have to rotate the wheel at a substantial rpm untill the repair sets, perhaps a powerdrill without a bit.
Nov 11, 2007 | Quinny Freestyle 3 XL Dusk Jogger
Quinny Buzz 3 Sulphur Jogger Logo
411 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
