Question about Pure Digital Flip Video Ultra Camcorder
Rotating images I own a Flip 5.0. I made the mistake of recording images in both horizontal and verticle angles. How do I rotate the images so that I can play/save them so that some aren't playing "sideways"!? -David
  • 3,083 Answers
You will have to download them to your computer, and then use software to rotate the pictures and resave them. A free, good program to do that is called Irfanview, just google it and you will find a site to download it from. The software allows you to adjust brightness, colors, rotate the pictures, and many options normally associated with a high-end product like PhotoShop, etc. When you rotate the pictures in Irfanview, you just pick "File", then "Save", and the picture will be saved in the present rotation. There may be software options on the camera to do this, but there usually isn't on most cameras and camcorders. Not having owned a Flip Video, I couldn't say for sure, but my bet is that it won't do it, and you will have to manipulate the pictures through computer software such as Irfanview or another viewer inherent on your computer.
Posted on Jun 06, 2010
How do i get pantech swift screen from horizontal to verticle?
Have you tried to turn off the Auto screen rotation? Try that and let me know your response.
Regards,
Harry
Supertechnician@outlook.com
+1 (503) 583-2414
Oct 02, 2014 | Pantech Swift Mobile Phone - Purple at&t
Tip
Rotating Text in Cells
In Excel, text of cells can be rotated to any direction or to a certain angle. It is called the orientation of the text. By default, orientation of text is horizontal.
To change the orientation of text, follow these steps.
  • Select cell or range of cells that contains data you want to rotate.
  • Select ”Cells” command from “Format” menu OR Press Ctrl+1, Format Cells dialog box appears.
  • Click Alignment tab of dialog box.
  • Specify angle in ”Degrees” spin box of orientation section.
  • Click “OK” button of dialog box.
on Jan 29, 2010 | Computers & Internet
Reverse image printing
Use photoshop to reverse the image then print. Image/image rotation Flip canvas horizontal Or vertical whatever you desire Then save image as (choose jpg if that is your choice) then give it a new name so as not to change the original picture
Nov 26, 2013 | Canon Office Equipment & Supplies
Laptop image is opposite when you capture images
Look at the settings of your camera Application and look for Mirror Image and put a check on it to get the exact image captured instead of having the image as the opposite when taking pictures or recording a video.
If not Mirro Image there should be an option for flip image horozontal and flip vertical, you just need to put a check on the Flip horizontal image or Mirro Image this depends on the Brand and the application as well of the Laptop this should correct the camera settings.
Most laptop cameras are now using a different format and needs to be set up on the application to get the mirror image of the snap shot or recorder video as what you are expecting.
I hope this helps.
Oct 03, 2011 | Computers & Internet
Need to rotate several Flip videos
When you watch a movie in a theater, have you noticed that the entire movie is in horizontal position? That's because you can't rotate videos.
Apr 05, 2011 | Canon PowerShot S410 / IXUS 430 Digital...
Hp pavilion dv6000 multiple images horizontally and verticle lines throughout the screen.
Does the video problem occur when connected to an external monitor?
If it does then unfortunately the most likely cause is either:
1. Bad memory modules, try pulling memory chips and rotating between slots to see if any change. If necessary replace faulty memory modules.
2. there is a very large number of these HP/Compaq models that have serious problems with the Video BGA chip coming unseated from the mainboard over time.
This can be repaired by reflowing the BGA chip, but is an involved process, and not for a standard user.
Otherwise the mainboard will need to be replaced.
Jul 06, 2010 | HP Pavilion dv6000t 15.4" Notebook Laptop...
My Sony KP-57WS500 TV has curved horizontal white lines. You only see them when there is something dark on the screen. Any ideas?
You have 3 CRTs inside of your TV that create image. Blue, Green and Red. Looks like one of them need adjustment due aging.
Remove front grille. Than remove center "shielding" piece held by 4-5 screws. Behind this cover you will find little black plastic box that have 6 rotating buttons on it. Take you time to study them. There is three columns and two rows. Columns represent color, rows - "Focus" or "Screen". You need to locate "Screen" row of three rotating buttons. They will be marked "B', "G", and "R" for colors accordingly. Turn on TV let it warm up and try to figure out witch color is dominating others on your screen. Then carefully turn rotating adjuster counterclockwise using Philips screwdriver. Try to muscle-remember original position of screwdriver so you can turn it back to it.
Eventually you will find the right one, you will see lines dissapear when you reduce voltage and reappear when you turn rotating shaft back. Sometimes more than one have to be adjusted.
Try to have all three color to be present and visible but with no over saturating and no horizontal lines.
Put cover and grill back - and that's should do it!
Regards.
Russ.
Apr 06, 2010 | Sony KP-57WS500 57" Rear Projection...
My monitor is verticle, won't flip back to
Try to use Cntl+Alt+Arrow keys to rotate the screen. Also go to display settings and change the monitor DPI setting will also resolve your problem.
Thank you for using Fixya.
Apr 02, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
8220 , trackball wont go down
Trackball doesn't work if you have not selected the sensitivity.
To select the sensitivity, kindly follow the steps:
1. Select menu.
2. Select option.
3. Select screen/key board.
4. Scroll down to find horizontal and verticle
5. Select horizontal-100 and verticle-100.
Oct 31, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Rotating the image.
Hi, I am not familiar with that model, But usually if you go into the settings menu you will see settings for the display which may be under "Display" "Rotate" "Keystone" "Flip" That model is made to be mounted upside down so somewhere in the menu there will be a setting similar to those I mentioned that will flip the image.
Hope that helps, Sorry I couldn't be more specific.
Sep 20, 2007 | Hitachi PJTX100 Multimedia Projector
Pure Digital Flip Video Ultra Camcorder Logo
255 people viewed this question
Top Pure Digital Video Cameras Experts
Rommel Balcita
sharky633
sharky633
tomikles
Level 1 Expert
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
