Question about Sony Playstation 3 (PS3) Console
PS3 will not start, period.
The lights will come on normally and all that, but the screen will remain black. Does anyone know what could have contributed to this problem? Any solutions? Please help!
  • 4 more comments
  • Anonymous Apr 11, 2008
    ps3 will not power up just saysa no signal
  • jdsafljsadf Apr 11, 2008
    I have a PS3 80GB. Came with version 2.0 of system software. I got it connected to internet and it requested the 2.20 update. I installed it and it installed without interruption. After reboot have black screen. Occasionally I will get the menu but it is frozen and I cannot move with either of my controllers.
    I have swapped from HDMI to standard video cables that came with it. No good.
    Under 2.0 I was experiencing occasional freeze ups. Now its toast.
  • dchamner06 Jul 10, 2008
    dude i got the exact same problem. nothing ive done works
  • Anonymous Oct 08, 2008
    when i put in any kind of game my ps3 has a error code 80010514 when it starts and it doesnt want to let me play
  • izzacsuarez Oct 26, 2008
    my ps3 starts just fine but the screen is black and i cant see nothing
  • Anonymous Dec 26, 2008
    To clarify, I have had a new playstation for a while, as it has been several months since I posted the problem.
    The lights on the system would come on, and occasionally, the system would turn on and everything would load up. It seems that the problem was that the system was overheating...at a tremendous speed. It would never last longer than a minute or two, and once it did overheat and freeze up, I would not start back up again until it sat there for hours to cool down, only to load up for a minute or two.
I contacted Sony CS. Rep seems to think my fan is out and might have fried CPU. Repair is $149.99 +tx.
I'm already into this thing for many hundreds of $$$. So going to send it to them and pray they can fix it. They'll fix or send one that is already refurbished. You get a 90 day warranty though so not sure if I'll hang on to it or not. Might just chalk it up to a lesson learned.
Posted on Apr 12, 2008
    Problem Solver:
  • 15 Answers
If you turn it off from the back instead of holding the button it could be a big problem and you will have to send it in for repairs or pay a proffesional to fix it. The first thing i would do is check the cables and make sure the video cable is plugged in. ( The yellow rca cable) and check that all the cables are pushed in all the way.(on the tv and the ps3)
Posted on Apr 10, 2008
OK this is not a solution, but strange that people are posting this. We were playing GH3 and everything went out. No power at all to the entire machine. I called Sony CS and now I have to prove we only purchased the machine less than a year ago. The CSR said this is UNUSUAL! Wow! I did a 3 second search and I found that this is PROBLEM! Thanks. Keep us posted on what comes of it.
Marie
Bmw e46 problems
May need a new oil pressure switch,it's located next to oil filter,remove electrical connector then part.You may have to remove oil filter to remove part.
Jan 06, 2014 | 2001 BMW 318i
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
My ps3 doesnt work and is because of a yellow light!!!
the hardware is done you cut the station off before without waiting
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
Power Light on but screen black
Try powering up with no battery connected. If that works then the battery may be faulty or too old.
Feb 15, 2009 | Computers & Internet
My ps3 will blink the tv screen on and of
Mine does something similar, just for not as long. On mine it's because the resolution of the display is changing. As far as I know, this is normal behavior. Have fun, the PS3 is a great system!
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
My playstation will turn on and the lights will come on an everything,...but the screen remains blank/black. The normal home screen will not come up...PLEASE HELP!!
its your tv... you have to make sure that it is the correct channel... it might be a pain, but go through the different channels such as : Video, Satellite, Composite, Tuner, VGA, etc...
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
During DVD movie playback, screen goes black periodically
it could be that the disc is and ordinary dvd disc and cannot stand the capability with a high def tv because i have the same problem and when 1 put a bluray disc in its fine
Mar 10, 2008 | Sony Playstation 3 (PS3) Console
Help to repair ACER Travelmate 290LCi
this is normally motherboard or powe side problem check your motherboard
Oct 19, 2007 | Acer TravelMate 290LCi Notebook
Sony Playstation 3 (PS3) Console Logo
6,625 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
