Question about Husqvarna 20" 60cc Rancher Chain Saw 460
I have a new hasky 460 rancher stalls when given
I have a new husky 460 rancher which stalls when given full throttle, What should I be checking?
  • 12 Answers
If it stumbles at full throttle, the fast (high) idle screw is set too rich. Using your owner's manual, locate the high idle adjustment and back it off in very very small increments. Do this until the saw will run wide open without stumbling.
Posted on Jun 13, 2010
High and low setting for hasqvanna 460
Husqvarna 460 Rancher Manuals
www.manualslib.com > Brands > Husqvarna Manuals > Chainsaw
Manuals and User Guides for Husqvarna 460 Rancher. We have 3 Husqvarna 460 Rancher manuals available for free PDF download: Operator's Manual ...
Jul 23, 2015 | Husqvarna 20" 60cc Rancher Chain Saw 460
2007 honda rancher efi idles then dies . you can flutter the throttle and it will come out of it but stall at base idle
Try cleaning the spark plug with fine grit sandpaper,make sure air filters is cleaned,then make sure carb is cleaned pilot or idle jet might be clogged. good luck
Feb 14, 2013 | RTO 200cc Full Size Four Wheeler ATV
Bought a new husky chainsaw a 455 rancher. was told i had to break it in on small logs & not run it very long at first. is this true
The factory usually recommends 2-3 tanks of fuel going easy on the saw and not running at full throttle.......but I have never done this on any of my saws and I don;t know anyone who has and my saws are all still running great.
May 20, 2011 | Garden
New 460 rancher 20" bar and chain cuts at an
It sounds like your chain is just dull.Or might not be sharpened right.This usually happens when the chain is getting dull.
Mar 09, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
Husquvarna 460 rancher 20" bar all new including
The normal reason for a saw to cut to the left, or right is because the cutters have been sharpened more on side than the other, they are now longer on one side, this then sends the cut off to that side. Measure the cutter lenghts, take the correct file and shorten the longer cutters
Mar 06, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
My chain saw will not rev all the way up, it chokes itself out before going to full throttle. It did this brand new right out of the box. 460 rancher
chances are that the settings are not set up right try opening the choke when you start it and leave it for about 3mins idling the slowly close the choke 3/4 quarters
if its not that im fairly sure its the spark plug i know you are going to say its new but some retailers put in very cheap plugs
John
Jan 21, 2011 | Husqvarna Chain Saw 20" Bar
Turning up the bar oil?
An “OM, 455e Rancher, 455 Rancher, 460 Rancher, 2009-09, EN, FR, ES” Follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-49.pdf
An excerpt from page 38 of the above OM follows (forcing it may render it inoperative):
Adjustment of the oil pump
Adjustments are made by turning the screw using a screwdriver or combination spanner.
The machine is supplied from the factory with the screw set to position 2.
Turning the screw clockwise will reduce the oil flow and turning the screw anti-clockwise will increase the oil flow.
Recommended settings:
• Bar 13"-15": Position 1 (full CW)
• Bar 15"-18": Position 2 (center)
• Bar 18"-20": Position (full CCW)
These recommendations apply to Husqvarna’s chain oil, for other chain oils increase the oil flow by one step.
WARNING! The engine must be stopped when making adjustments.
All OMs and IPLs can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
No oil to bar or very little, have parts, need diagram to install husqvarna 455 rancher 460
HusqvarnaUSA.com
06 1500198
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 14, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 20" 60cc Rancher Chain Saw  460 Logo
521 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
