Question about Garden
Blade for Snapper riding mower. I have two blades for my riding mower. One is the double cut mulching blade and the other is a single cut hi lift blade. The mulching blade cuts the grass very finely but does not lift the grass to get a good clean cut. The hi lift blade gives a clean cut but the cut grass looks like hay. Question....Is there a blade available that will do both jobs, lift and finely cut too?
  • Gerald Gier Jun 10, 2010
    Actually led me to another site. The Gator blade by Oregon...Thanks
  • 776 Answers
As you have not mentioned the model no. of the product I am providing you link which will provide you different blades that fit on Snapper mower:
http://www.rcpw.com/snapper-blades.html
Ever machine is designed in such a way that they can cut different kinds of grass, with different blades, however there are couple of machines which can work with single blade. As you have not mentioned the height and width which your blades cut, just look in the baove provided link to see if something can fit your requirement.
Process for changing the blades:
http://www.gardenguides.com/104259-change-snapper-lawnmower-blade.html
Please let me know if you need any further information, or any more information you can add.
Posted on Jun 09, 2010
How can i get more blade speed from my 355z snapper
what for you have 26hp. what are you trying to cut. check your blades are sharp. and dont expect it to act like a mulcher.
Jul 28, 2012 | Briggs & Stratton Snapper 5900748 355Z...
I have a model 944-604810 riding lawn mower and find that it leaves a trail of cut grass even though it is equipped with a mulching blade and a new mulching cover. It would appear that the grass is not...
yes that is most likely the cause of it, also, you have to cut more often when mulching, and the higher the cutting deck, the more likely the grass will blow out without getting mulched enough. More than likely, the blades are dull, and/or the grass is too high, or possibly even wet if it is high.
Aug 23, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Rear bag not collecting grass
Check the blade is on right side up - this is about the only thing that makes a difference - the blade - if a mulch blade may be making the cuts too small to toss them into the bag ?
Hope this helps - please vote me as helpful and leave a comment - if you need more attention I will answer back -asap - also be sure the blade isn't worn out - -
Gary
May 11, 2010 | Black & Decker 19" Electric Lawnhog...
My john deere lt 133 mower with a double blade mulching deck, 1 blade stopped working and only 1 blade cuts now, how do i fix this. Thanks Patrick
This model mulching deck uses a flat/ribbed serpentine belt that is set at very high tension.When belt breaks under the cover only one blade will turn due to IT being driven from PTO clutch as the other blade being turned from serpentine belt.This deck was Deere's first and last shot at making a true mulching deck and only made it a couple years.When you buy the VERY expensive belt it will come with detailed instructions on how to install it.Goog luck.
Aug 07, 2009 | Garden
What is the difference in a regular blade and a mulching blade?
A regular blade has a straight cutting edge, a mulching blade is bent to have a high and low cutting edge. Even if you have a mulching blade on, if the grass is too high or wet or you're cutting too low, it won't do a good job and may require a second pass.Raising your cutting height can help. Hope this helps. Dwain
May 17, 2009 | Craftsman Garden
New black and decker lawn mower, MM875 starts but I cannot get it to cut, what am I doing wrong?
did you sharpened the blade. checked the blade if not installed reverse.B&D clean the blade. info in the blade say's facing the grass
Aug 17, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
