Question about Garden
Blade for Snapper riding mower. I have two blades for my riding mower. One is the double cut mulching blade and the other is a single cut hi lift blade. The mulching blade cuts the grass very finely but does not lift the grass to get a good clean cut. The hi lift blade gives a clean cut but the cut grass looks like hay. Question....Is there a blade available that will do both jobs, lift and finely cut too?
  • Gerald Gier Jun 09, 2010
  • 2,272 Answers
Yes .Such blades available for 2in 1 cutting jobs.Its called High Lift Mulching Blade The cost of this blade is near to $22. If you want to get this blade please click on the above mentioned link and check the picture of blade http://www.jackssmallengines.com/BladesDetail/SNAPPER%20/302816 ---------- Also if you require any other type of blade for your snapper riding mower please click on the above mentioned link http://www.jackssmallengines.com/blades/snapper_Blades ------- Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jun 09, 2010
  • 516 Answers
Broadly speaking, lawnmowers come in two styles---the reel, typified by your venerable unpowered push mower, and the deck, or rotary, which describes most of today's powered, walk-behind machines---so deciding between blade designs is simple. Some brands of deck mowers accept several types with slight differences in performance and function. Still, mower blades made by different companies do not fit all types of machines even if the deck measurements are the same. Choices for older machines could be limited.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
    Reel Blades
  1. Still appropriate for small yards, the wheels of push mowers drive a blade cage revolving against a cutting bar with a fast, scissoring action as owner-operators provide the motive force. Sharp blades make a noticeable difference in ease of operation. The only blade option is the one that fits, so replacing the mower could be as reasonable as replacing the blades.
  2. Deck Blades
  3. Deck mowers cut with many variations of the same basic blade---a flat horizontally mounted steel bar that revolves like a fan blade and cuts with both leading edges. Blade shape and mounting hub could be uniquely shaped to fit one company's model of mower. Universal mounting blades do not fit all machines. Your best source for replacement blades or alternative blade designs is the company that made the mower.
  4. Lifting Blades
  5. As the rotary mower passes across your lawn, the deck presses down the blades of grass. Air pressure from the cutting blades may keep the grass down, resulting in a ragged cut. In heavy grass, tufts and rows of partly cut grass often lift up behind the mower. With lifting blades, a section of the blade's back edge turns up toward the deck. The draft generated by this blade shape pulls grass up, toward the cutting deck, and improves the quality of the cut. Blades are available in low-lift and high-lift designs for some machines.
  6. Mulching Blades
  7. Mowing a healthy stand of grass creates a large amount of clippings. Left in clumps on the yard, the clippings can suffocate and kill small patches of lawn. To reduce this problem, mulching blades use high-lift designs with added features like notched or rake-toothed lifting edges. Because of this extra blade action, clippings revolve beneath the deck for a longer time. The mower chops them into a fine mulch that disappears between grass stems and fertilizes the lawn.
  8. Tips
  9. While high-lift and mulching blades are an improvement over the simplest blade designs, do not expect perfect results. Mulching heavy or damp grass often clogs a mower deck with clippings, bogging down or stalling the machine. Cutting several inches of tall grass will not yield a clean-cut, finely mulched lawn in one pass. Adjusting mower height downward by one or two inches per pass gives better results. Dull blades exaggerate all problems.
Posted on Jun 06, 2010
How can i get more blade speed from my 355z snapper
what for you have 26hp. what are you trying to cut. check your blades are sharp. and dont expect it to act like a mulcher.
Jul 28, 2012 | Briggs & Stratton Snapper 5900748 355Z...
I have a model 944-604810 riding lawn mower and find that it leaves a trail of cut grass even though it is equipped with a mulching blade and a new mulching cover. It would appear that the grass is not...
yes that is most likely the cause of it, also, you have to cut more often when mulching, and the higher the cutting deck, the more likely the grass will blow out without getting mulched enough. More than likely, the blades are dull, and/or the grass is too high, or possibly even wet if it is high.
Aug 23, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Rear bag not collecting grass
Check the blade is on right side up - this is about the only thing that makes a difference - the blade - if a mulch blade may be making the cuts too small to toss them into the bag ?
Hope this helps - please vote me as helpful and leave a comment - if you need more attention I will answer back -asap - also be sure the blade isn't worn out - -
Gary
May 11, 2010 | Black & Decker 19" Electric Lawnhog...
My john deere lt 133 mower with a double blade mulching deck, 1 blade stopped working and only 1 blade cuts now, how do i fix this. Thanks Patrick
This model mulching deck uses a flat/ribbed serpentine belt that is set at very high tension.When belt breaks under the cover only one blade will turn due to IT being driven from PTO clutch as the other blade being turned from serpentine belt.This deck was Deere's first and last shot at making a true mulching deck and only made it a couple years.When you buy the VERY expensive belt it will come with detailed instructions on how to install it.Goog luck.
Aug 07, 2009 | Garden
What is the difference in a regular blade and a mulching blade?
A regular blade has a straight cutting edge, a mulching blade is bent to have a high and low cutting edge. Even if you have a mulching blade on, if the grass is too high or wet or you're cutting too low, it won't do a good job and may require a second pass.Raising your cutting height can help. Hope this helps. Dwain
May 17, 2009 | Craftsman Garden
New black and decker lawn mower, MM875 starts but I cannot get it to cut, what am I doing wrong?
did you sharpened the blade. checked the blade if not installed reverse.B&D clean the blade. info in the blade say's facing the grass
Aug 17, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
