Question about Ford 8N Tractor
When running tractor has white smoke coming out of exhaust and it smells like fuel. the owner before me just put a new head on it. don't really know why but he did. the carburetor was also just rebuilt.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
White smoke out the exhaust is a sign of water burning or getting into the exhaust system and steaming out. It is possible he got the head gasket on wrong or it has blown another head gasket. I would run a compression test on each cylinder. You can get a screw in compression tester at my auto parts stores that will screw into the spark plug hole. It will come with instructions also.
I know this doesn't fix your problem but it will help you get started in isolating it.
Posted on Jun 17, 2010
Car started smoking heavy fuel smell coming from exhaust and idles rough
White smoke is water in the cylinders/exhaust. (bad head gasket) White with a bluish color is oil. Black smoke is to much fuel. Which do you have.
May 19, 2015 | Cars & Trucks
Spitting sputtering
These things are notorious for having crank sensor failures. Not too expensive and not too dificult to replace. I would try that first.
Jan 14, 2014 | Ford Explorer Cars & Trucks
2001 Dakota compression loss, smells like gas, white smoke from exhaust
Sorry but this has happened to me before, you might have a blown head gasket. that is where oil and or water are getting in to the piston cylinder and causing the white smoke cause the oil and water is being burnt or boiled.take it to a shop unless you have all the right tools and knowledge to do this job. i cost me like $1500 labor and parts.
May 26, 2012 | 2001 Dodge Dakota
My 98 vt commodore has a vibration coming from the exhaust, idles low, has white spark plugs, sounds like its sorta missing, a fumey smell and a lil white smoke coming from exhaust. i have replaced oi
check the compression in all cellenders you might have a blown head gasket, burning smell might be the gas in blown cillender not igniting
Feb 12, 2012 | Cars & Trucks
Engine light on and white exhaust coming out
white smoke out off exhaust is coolant getting into cyl like a bad head gasket to much fuel would be black smoke
Feb 19, 2010 | 1998 Ford Explorer
Gas smell in exhaust
you have either a blown head gasket or cracked head. The white smoke is coolant passing through the engine and exhaust. The gas smell is from compression leaking past the gasket or head, pushing fuel vapor into the air.
Dec 01, 2009 | 1993 Toyota Paseo
White smoke from exhaust smells like gas
a tune up will not cure smoke, sounds like u may need a head gasket replaced.
Jun 17, 2009 | 1996 Oldsmobile 88
No Power,Fuel Smell ,White and Blue Smoke coming from exhaust.
It sounds like you have a blown head gasket, or maybe both head gaskets....it has all the symptoms of such.....
May 08, 2009 | 1992 Toyota Camry V6
White smoke and smell of eggs
White smoke in the exhaust, more so on a cold start. That's steam. Water is getting into the combustion chamber. Most likely coolant.
Put your hand in the white smoke to capture the odor. (don't burn yourself)
What does your hand smell like? Coolant (anti-freeze & water) smells sweet.
Likeliest cause = head gasket. Possible = cracked head - depending on how hot it got. Less likely = cracked intake manifold.
Maybe a blown head gasket
Apr 01, 2009 | 2006 Ford Focus
Hard starting smokes white like gas is getting into cylinders
White smoke in a small engine is oil. Oil in the cylinder will create too much pressure for the engine to achieve compression. Make sure the engine is not getting fuel into the oil and thinning the mixture (literally smell the oil... gasoline and oil smell nothing alike, if it smells like gas, it is). If this is the case, the carb is leaking fuel into the engine, thinning the oil and causing the oil to leak past the rings into the cylinder head, through the valves and, from there, into the exhaust to burn off. Black smoke indicates a direct fuel issue in a small engine, white is oil based.
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Ford 8N Tractor Logo
883 people viewed this question
Top Ford Toys Experts
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
