Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Blades will not engage
Hit a stone and the blades stopped rotating and now will not engage. I checked for a blockage around the blades. The belt is still intact. The mower is 4 hours old....just purchased it.
    President:
  • 1,961 Answers
Is the engine running?if so,try to check the srews holding the blade they might got broken or the connecting rode that connects the rotor and the blade they might as well broken or loose..tnx
hope i helped you...
Posted on Jun 06, 2010
Craftsman Model Number: 917.377151 motor shuts down when blades engaged
The engaging of the mowdeck is cause an excessive demand of your engine. From that, we can assume your problem is in the deck. Since the power drive is all about belts and it threw the belts, from your information I can only deduce that either an object (stick-wood-rock) has wedge into a position that has stopped rotation of the blades. Also, each blade has a pulley/spindle. These have bearings which must be free to rotate.
A bearing failure or seizing can also cause the problem you report.
Follow safety rules in your manual to insure the engine cannot start. Attempt to rotate each blade to check for free rotation. If the do not you most likely will need to remove the mower deck and check further. An obstruction or seized spindle should be easy to determine and sit repair is easily possible.
Sep 03, 2016 | Craftsman Garden
Blade engagement HDK19H42 Ryobi Tractor
Check the belt routing. I've had a belt that was a little stretched out grab the pull incorrectly and the force stopped the engine.
Jul 28, 2015 | Garden
Ran over a tree root and bent a blade. Replaced blades. Checked belts. Belts are fitting loosely. Mower won't shift into gear fwd. or bkwd. Transmission not engaging. What might be the problem?
The gear would, obviously, have been engaged when you hit the root. I presume this will have caused some resistance in the friction material of your transmission. Consider the engine rotating the trans and the root stopping it from rotating, the transmission and the blade will have borne the brunt . Have your transmission checked for damage
Jul 16, 2015 | Garden
Model # 917.289072 19.5 42" When i engage blades it is very noisy like metal on metal It seems to cut ok but I don't want to mess it up more I changed blades and changed oil
Did you check the spindle assembly. I had one that cracked on my mower and had to replace it.It could be broken at one of the corners and this makes the blade spin off balance or not turn at all.Or a pulley could be worn or bent and the belt makes it rotate against the other metal parts.This happened because I hit some stones. They can damage other parts of the mower deck as well as ruin the cutting blades.You can do an online chat with SEARS parts too and their tech may have more info which may hepl diagnose the problem. Good luck,
Jean
May 27, 2015 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower blades won't engage
Did the smoking stop when you disengaged the blades? If so it is most likely your belt that is smoking. Make sure all the blades turn freely by hand to ensure you have not hit anything that may have bent a shaft on one of the blades. If one of the shafts is bent and wont turn FREELY, the belt driving the blades would slip and start smoking as it tried to turn them.
Apr 19, 2015 | Garden
My craftsman DLT 2000 won't cut grass , the pulleys are clean n moving the blades are rotating but when I let the deck down to cut the grass it stops and sounds like the belts trying to turn, making the...
be sure the blades are not bent and you dont feel any wiggle when pushing them up and down. be sure nothing is wrapped around the spindles. be sure the belt isnt damaged and tight when the deck is engaged to cut with the engine off.
Sep 18, 2017 | Garden
Blades won,t disengage
Assuming this is a lever actuated deck (not electric p.t.o style) I would be checking the belt pivot tensioner assembly which the cable would be hooking to a lot of times moisture will get between the pivot and the deck and rust up not allowing the heavy return spring to slide the pivot back removing the tension from the belt. If you spray the pivot with a good lubricant and hand work the pivot tensioner back and forth it should loosen up. Usually it's the other way around and the 1st time of the year you use it you can't get it to engage.
Jul 13, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Ariens Sport Zoom 1440 blades engage slowly
check that the grass has not bunched up around the spindle and shaft in such a fashion that it is jamming the blade to the deck and acting like a brake
Jun 06, 2013 | Garden
Was mowing the lawn and the blades stopped rotating and won't engage.
Check that the belt didn't break. If the belt is fine check the pto it may not engage the blabes. Some pto's are electric some manual. Depending on what you have to do to engage the blades. That will tell you where to check.
Oct 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
145 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
