Question about Sharp DV-SL2200W Player
Sharp DVD DV-SL2000 Always shows no disc Tried lens cleaner Tried original CD n DVD No response
3 Suggested Answers
SOURCE: Sharp DV-RW340 Compatible Discs
I have had great success with Dynex Model DX-DVD-R25.  They are specifically: 4x  120min.  4.7gb. It's a spindle of 25.   The UPC Code is 00603 10116.  Now I'm searching for more myself!   These discs have worked well for me and play great in other DVD players, as well.  If you find 'em... please post it here!
Posted on Dec 27, 2008
  • 4 Answers
SOURCE: Can't Read Disc
You could try updating the firmware.
Posted on Jul 29, 2010
Panasonic DMR-EZ48V Dvd unit said disc was scratched/dusty - so would not record. Tried a newly opened DVD disc - same problem. Tried a pre-recorded DVD that had previously been played on this machine...
I would suggest since this is just out of warranty/guarantee as you say, try a DVD laser lens cleaner (these look like DVDs but they are for shifting surface dust off the laser lens in these drives (without the need for you to worry about opening them up). If the recorder suggests dirty discs, the laser probably has a speck of dust on it - you cannot see this speck, but the device can.
Do not use CD/DVD lens cleaner discs - those are supermarket products designed for CD/DVD players, not recorders or DVD-ROM drives in a PC. I recommend a true DVD lens cleaner kit - you may be able to obtain this through Panasonic or similar electrical outlets (like where you originally purchased the combo). These 'specific cleaners' are cheap, but unlike CD/DVD cleaners, these will not damage your unit.
Hopefully it is nothing more than a bit of stubborn dirt stuck on the lens inside the drive or anything more serious.
Feb 24, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Stopped playing after I inserted damp CD in 200 disc loading mechanism
this can be due to some moisture in lens.
leave the unit to get dry for 2 days.
Jul 04, 2008 | Kenwood DV-5700 Multi-disc DVD Player
Selective playing of DVD's on Sharp DVD Recorder
Given that the machine will read disks it has written itself but not play regular discs, I suspect the lens assembly is slightly out of alignment and needs adjusting. This is not normally something you can do at home unless you have the correct test gear. It will need to go to a repair shop. One thing you can try before that is to clean the lens. Buy a quality (Scotch 3M, Philips ) cleaning disc and try it. Could be it's only a speck of dust on the lens.....
Aug 01, 2007 | NAD C541 CD Player
Image/Sound Freeze-up
the problem is the laser, or lens of your dvd, try cleaning it using lens cleaner..
Jun 21, 2010 | Sharp DV-600U DVD Player
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony Televison & Video
Despite all trays having a cd in them system shows No Disc
Sounds like your laser lens is dirty. Cleaning disc usually dosen't work. Have to clean lens with alcohol and cotton swab/q-tip. If this doesn't work the optical pick up assembly will have to be replaced.
Jan 05, 2009 | JVC FS-G5 CD Shelf System
Bad Disc Error
you want to clean your player lens. with the help of lens cleaner cd! dont use dirty disc inside the player! it spoil the lens!
Jul 07, 2008 | Daewoo DV-6T955B DVD Player/VCR
ONKYO DV-SP301
the play head of your device known as the ''lens'' is either dirty or bad thats why its selecting disc,try clean it with lens cleaner,if it still does the same thing call your technician,and tell him to change the lens for you.if he does the right thing ,it will work perfectly well.
Dec 13, 2007 | Onkyo DV-SP501 DVD Player
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Sharp DV-SL2200W Player Logo
133 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
