Question about Ford Tractor 8n Front Emblem
Kohler engine on troy bilt super bronco is blowing oil out the exhaust and air intake. Engine will start sometimes but dies out. smoke is coming out of the engine as well. white or blue smoke.
  • A Miller Jun 06, 2010
    what is the oil level? breather clear?
  • 3,600 Answers
It is out of time or you have burnt valves. You will need to take it to a shop to get it repaired.
Posted on Jun 06, 2010
What is the spark plug gap for the engine of a troy bilt super bronco crt tiller
go to troy blit and input model number, this will tell you what you need to know
Jan 22, 2015 | Troy-Bilt Super Bronco 16-inch 208cc...
I have a troy bilt fronttine garden tiller . Why does it blow whitebsmoke out exhaust?
WHITE smoke is generally associated with antifreeze, but that won't be the case with your air-cooled tiller (it has no antifreeze). It's my best guess that it's blueish smoke, which is associated with oil burning - I suspect that your engine is about ready to be rebuilt or replaced.
Apr 25, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Have a troy bilt trimmer mower 5hp that is at least 10+ years old. very hard to pull start, when it does start it chugs about 5 seconds, and dies. like the spark plug really never gets it fired up. also...
you could have several problems with your engine . one it could be off timing it could have a sherd flywheel key or you could have a stuck ring or bad rings also a scored wall.. white smoke is oil if you have tipped it over you have to let the oil burn out of the cylinder if you believe its your plug take the plug out and clean it off with some gas and a soft wire brush and put it back in see what happens .
Nov 04, 2013 | Troy-Bilt Garden
Why is my exhaust leaking oil and blowing out grayish color smoke
Your piston rings are worn to the point that oil is getting into the cylinder and some is being ejected through the exhaust and some of the oil is being burned causing the grayish smoke.
May 07, 2012 | Troy-Bilt Super Bronco CRT Garden Tiller
I have a 19 hp Troy Bilt Super Bronco with the
sounds like spring tension on top of deck is connected to a bolt post,mine broke and went missing with the spring,blades kept slipping,didnt know how to tighten belt,go figure
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My Troy-Bilt mower starts easily but not as powerful, stays on for less than 5 minutes and gradually stops. some black smoke is coming out
If the black smoke comes out of the muffler, you are burning excess fuel and could have an air filter plugged up to restrict air intake and cause the engine to run rich, therefor black smoke.
Apr 18, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
Oct 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
I have a Troy Bilt Bronco, Kohler 18 engine
its the coil it has the same one as a 12.5 has
Sep 18, 2009 | Garden
Riding mower engine loud and smoking.
take it to a reputable shop and have them check it over - courage engines had a problem when they first came out - the bolts in the cover plate were not torqued properly and when they come loose, the torque of the engine turning will crack the block - this should be a warranty condition if the block is cracked - just make sure the shop is a kohler warranty station
Aug 27, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Smoke and oil coming out of the front exhaust of
chech engine oil level ,if oil level its up carburetor flout neddl valve leak and the fuel run into engine
Aug 22, 2009 | Garden
Ford Tractor 8n Front Emblem Logo
949 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
