Window air conditioner
Can i put a window air conditioner--
through a wall---
window ac--are half the price of thru the wall air conditioners--
i think i know someone who has done this with no problem--
im just making sure with you guys---
  • A Miller Jun 06, 2010
    purpose of a window AC is so you dont have to cut through the wall. if you cut through the wall ...now you have to 'refinish' inside and out. Window AC does not facilitate removal in through the wall installation. there is no cheap way out ... that is what this guy thinks
    President:
  • 1,515 Answers
Hi, yes you can put a window unit through a wall. Just make sure that the condensation will drain from the indoor coil to the out side which it should do on its own design. Also, make sure that the condenser coil at the rear of the unit is all out side. You will have no problems at all. You can use 2- peices of small chain at each corner and use small lag bolts to secure it to the wall. Looks better then to build a frame to set it on for support. Yes, they are made to install in either place.
Best of Luck,
Shastalaker7
Posted on Jun 06, 2010
I need to order a new fan for inside my air conditioner
Hello, here is a link for parts for your AC http://www.searspartsdirect.com/partsdirect/part-model/Haier-Parts/Room-air-conditioner-Parts/Model-HWF05XC7/3126/0904032/50033646/00001
Jul 13, 2011 | Haier HWF05XC7 Thru-Wall/Window Air...
I can't find one this model replaced model 74054 purchased in 6/10/93 thank you
Your message was a little confusing. But, if you're looking for the Kenmore 75050 Thru-Wall/Window AC, you can find it at Sears online at the following link.
http://www.sears.com/shc/s/p_10153_12605_04275050000P?keyword=kenmore+75050+thru-wall%2Fwindow+air+conditioner&sLevel=0&prop17=Kenmore%2075050%20Thru-Wall/Window%20Air%20Conditioner
Hope this helped you find the model you wanted. Please let me know. Thanks.
Jun 09, 2011 | Kenmore 75050 Wall/Window Air Conditioner
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
AF-S80MX Thru-Wall/Window Air Conditioner: What kind of refrigerant does this unit uses? ...
Most new window units are using R-22 or it's most common alternative R-410A - but you will need to check the 'data tag' on the AC to be sure. All AC units have a data tag (either metal or paper label) - somewhere on the AC - which gives you model number, size, voltage, and type of Refrigerant, as well as other info.
good luck!
May 08, 2010 | Sharp AF-S80MX Thru-Wall/Window Air...
AC 'squeak'
inside fan blade could be hitting styrofom houseing
Aug 27, 2009 | Fedders A6Y12F2D Thru-Wall/Window Air...
Why does my airconditioner leak
If this is a window ac then you need the back of the ac lower than the front, so the water can drain to the back.
Aug 18, 2009 | GE AZ28E15DAB Thru-Wall/Window Air...
Can I mount a Samsung AC unit thru wall rather then window?
as long as the vents are completlyeyt covered. and cove rit in winter
Mar 15, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Thru the wall AC units(small)
If the Ac unit can not fit your window, you can put a wall unit, you don’t have to open the wall and mount a stable unit, you just need to buy a portable AC unit put on.
This way cost you not too much.
Jul 09, 2008 | Haier hwr10xc6 Air Conditioner
Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
Jun 10, 2008 | Frigidaire FAH106N1 Wall/Window Air...
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
