Question about Sony Ericsson K800i Cellular Phone
The joystick wont function if pressed - Sony Ericsson K800i Cellular Phone
    Sergeant:
  • 280 Answers
The joystick in Sony Ericsson phones are too delicate. If you find them non-functional, you can get it replaced at a local service centre
Posted on Jun 06, 2010
When i push power button on lights blink constantly, wont move
For future reference, here is the is a procedure for
Locking/Unlocking the VSI
The VSI has a feature that enables you to
lock your powericon1.png chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speedicon1.png/profile indicator should ripple up and down.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked.
Mar 16, 2014 | NRS Hoveround MPV 5 - Used Power...
My computer is unresponsive to the joystick; I plugged it into the usb port a message confirmed it was installed and ready for use but nothing happens when I move the joystick in a flight simulator or...
Hello, Here's the solution to your problem, you have to configure the games you're playing for the joystick to work, I believe all games have this option, ussualy in the "configure keyboard and mouse" options menu, click on any funcion you want your joystick to use for each button, and then press the button you want for that function, do that with all buttons of the joystick you want to use, some games need the joystick axis to be configured, just click on left/right and move your joystick in the desired direction, same procedure to up/down, if your joystick has a throttle wheel, do the same for it (if needed).
Procedure is simple and most games has small variants of this procedures I gave you, but they are simple to figure out.
Hope my solution helps, have a nice day :)
Apr 14, 2011 | Trust Predator TH 400 (12629) Joystick
I have a logitech wingman xtreme digital.......will it work with Window Me, I had it with an old computer with Window 95/98 and it worked.......on this other computer it does not....Why?
The older the computer considering innovation makes likely the incompatibility to joystick devices. Compartilities also includes the purpose resourcefulness of the computer devices. For example, an old computer may have been manufactured compatible to older joysticks. Usually, old computers are shy of media enhancement features enhanced with modern devices. Joysticks least achieves productively with computers that least have the entire media experience. Verify the innovativeness of the joystick. An older joystick of the computers generation may likely become compatible. Recent devices like joysticks are least comparable to prior devices because of the built-in program requirements. Prior devices required Disk to install. The disk was only compatible to the computer that was designed to suit. Recent devices are plug_and_play least present on prior computers. Once plugging a recent device to an old computer, plug and play may not display. While attempting to download the disk program may least be compatible to the built in device. Usually electronic devices are generationally comparatively where computers compatible to peripheral devices. The joystick may be compatible to the computer as a device to device communicating. Once the software program that request joystick functions are modern innovations request features least present with computers that are maleficent. For example, recent joysticks that are generic would plug and play on every computer of recent innovation. The malfunction is experienced with the purpose function of the joystick. Simulator devices programs require several pixels from the computer to attain displays. The joystick may be connected to display lit displays. The software program however may require resolution over surpassed by both the computer and joystick. Every devices of computers hardwires, software's connections have to be designed as preserved functions to achieve desirable effects.
Feb 06, 2011 | Logitech WingMan Extreme Digital Joystick
My panasonic PTLB60NTE shuts down after couple of minutes when I use wireless mode. How can I solve this?
There is three indicators lights on the panel
1. lamp indicator.
2. temperature indicator.
3. computer input indicator.
If your projector shutdown itself without given any indication its mean that your projector function POWER OFF TIMER is on. You can off this function.
How: (two keys back side of projector one is menu second is a joystick witch have 4 arrow keys and center press is enter)
press MENU button to display the menu screen and then use joystick UP or DOWN to select the OPTION menu. press joystick to ENTER and then use joystick UP or DOWN to select POWER OFF TIMER use joystick RIGHT or LEFT to select DISABLE then press MENU two times to exit the menu.
If your projector shutdown itself with given any indication then
If LAMP INDICATOR flashing RED then lamp circuit failure its need to be repair or replace.
If TEMP INDICATOR flashing RED then the temperature inside and /or outside the projector is abnormally high.
CAUSE: The ventilation opening are covered. The room temperature is too high. The projector is located at high elevations (above 1400m)
REMEDY:clean the air filter. Remove the object from the ventilation openings or clear around the projector. Set the HIGHLAND option to ON
Jan 04, 2011 | Panasonic PT-LB60NTE LCD Projector
My w200i joystick is not functioning..i already replaced it but it doesnt work..
Use numeric pad at most function of the phone working
like if u want to select setting press #
............................radio press 9
..............................massage press 5
now .............................inbox press 2
now view the massage abd read it
massage is more than screen press more and 2 for forward
the remaing part is now form the back
now delete character for c button and read
Dec 07, 2010 | Sony Ericsson W200i Cellular Phone
How do you set the correct time ???
Press and hold the source button until the unit turns off. Then with the power off, press and hold the multi-function control (i always call this a joystick since you can move it left, right, up or down OR press it like a button and it reminds me of old video game controllers). When you press the joystick for a moment it will bring up an initial settings menu. Scroll to the clock option and press the joystick button to enter. Use left and right to select minutes and hours and use up and down to change to the correct time and you're done. Press source again to turn the unit back on and you should be good to go. Enjoy!
Dec 01, 2010 | Pioneer DEH-P5900IB CD Player
My chair wont move the lite diplay shows 7 lights the joy stick feels like it is out of the sosket
If you have a vsi joystick seven bars means there is a possible joystick trip
a joystick trip is indicated . Make sure the joystick is in the center postion before switching on the VSI.
It may also be locked try this.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mimobility
Oct 08, 2010 | Pride Jazzy 1103 Ultra Standard Power...
MASTER RESET CODES FOR SONY ERICSSON
Here are the Master Reset codes for your phone.
Master Reset / Codes
Accessing the Service Menu - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key.
Checking Firmware Version - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key, press 1 key twice.
Show IMEI # - press * key, press # key, press 0 key, press 6 key, press # key
Manual brightness adjustment - While in camera mode, press and hold * key and move joystick to lower brightness, press and hold 0 key and move joystick to increase brightness
Quick ScreenSaver - Pressing # and * at the same time
Show screensaver and lock keypad - press * and lock keys
*#0000# - Reset language back to english
Hard Reset -Hold power for 10 seconds
May 28, 2009 | Samsung SGH-D500 Cellular Phone
Blinking display
I think i kinda know what problem you guys havin, here what you need to do first:
1) Turn the Unit off
2) Press and hold the Joystick (multi-function) button for about 3 seconds or until you hear the beep
3) Turn the Joystick around clockwise until you see "Demonstration" ON
4) Push the Joystick for "Demonstration" OFF
5) Press Band when you finish
let me know if you have more any problems
Jan 03, 2008 | Pioneer DEH-P6800MP CD Player
Sony Ericsson K800i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
