Question about Pioneer DVR-220 DVD Recorder
My Pioneer DVR 320 des not power-up The fuse is OK There is power on the circuit board I suspect a power surge on power faiure One part id as AR1 tests open I do not know what that AR1 part is looks like a resistor but may be an MOV or diode Thanks for your assistance dunnharvey@videotron.ca The power on light does not light-up
    Genius:
  • 1,121 Answers
Need to check the power supplies outputs (voltage).
Posted on Jun 06, 2010
Power surge brand new maytag fridge not cooling
That power surge probably burnt out the guse on the circuit board. I suspect you may need a new board unless you know an electricity geek who can replace the fuse. New I would check your warranty. That circuit board might cost $200. plus..
Dec 21, 2014 | Maytag MSD2756G Side by Side Refrigerator
My DVR 433 H-K does not power up. Already checked the 220V AC power cable. Everything OK with the cable. I suspect it is the fuse in FU01. What do you think ?
If the DVR is dead it could be the primary fuse.Typically its a 1.25Amp fuse.But remember a fuse does not blow with out provocation, there might be a short circuit else ware esp: the regulator chip.
After replacing the fuse turn it on with a 40 to 60 watt incandescent light bulb in series. On turning it on if the bulb remains glows full bright -- indicates a short circuit further up. Most probably the main switch mode supply IC must be at fault.
Jul 06, 2011 | Televison & Video
My Pioneer DVR 320 dvd recorder just stopped working. Iv'e checked the power source thats Ok. Is their a fuse or something or is it old age?
Tries unplug,replug the unit back like about an hour later,see if might just in it protected mode,see if the unit reset itself and work again.Yes,there is a fuse in the back of the PCB board,it seat near the power a/c cord.U can tries to replaced the fuse and tries it out.But all modern electronic devices saldum burn fuses in a normal uses.
Jan 29, 2011 | Pioneer DVR-320S DVD Recorder
My Pioneer DVR-520H DVD Player works fine but sometimes when it is powered off the power just goes completely. When this happens I plug it into a different socket or just pull out the power cable from the...
It seems problem with power supply board in Pioneer DVR-520H, possible causes for that symptoms are few dried up/ leaky capacitors, cold/ dry solder joints on circuit board or chip resistors would be devalued.
Local repair shop will help you to replace bad capacitors, chip resistors in power supply board to solve this issue if you are not familiar with soldering work in circuit board.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 11, 2011 | Televison & Video
Pioneer DVR-220 will not power up. Any suggestions.
First check the in line fuse...it sits right behind the electric plug on the chase..You have to remove the screws to open the case to check this....If the fuse is okay, you will have to replace these two capacitors, 10 volt, 3300uf, and 10 volt 1000uf...they are located on the same board that houses the fuse...the two location are c23 and c19 on the power board...
Jul 08, 2010 | Pioneer DVR-220 DVD Recorder
Monitor just went off. no power light. changed fuse but monitor is completely dead
possibly a power surge killed the main board in the LCD. if the fuse was blown i would suspect a power surge. you could replace the circuit board. either that died or the power supply died- depending on if it has internal or external power supply that might be blown as well.
i would take it to a professional LCD/ LAPTOP repair person. they should be-able to test it and let you know what needs to be replaced
Aug 06, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Pioneer DVR-320-S is dead.
Well if it is dead and the transformer is getting power then next step is the processor.  Which if it is dead, then I am sure all the internal components are as well.  My recommendation is have a professional give you and estimate and buy a UPS unit that will regulate the power to you important expensive units such as this.
Jan 06, 2009 | Pioneer DVR-320S DVD Recorder
"HDD REPLACEMENT IS NOT VALID..." error message
Go to http://support.dell.com/support/edocs/systems/latd630/en/AMT/MEBX.htm
You have to disable Intel ME State Control , and you do not get any pop up masages any more.
I hawe that problem with secundary HDD.
Regardes.
Oct 12, 2008 | Pioneer DVR-213LS DVD±R Dual Layer Burner
In line fuse
I suspect that the fuse is 0.75 A, and I believe that it is soldered in place. Can you see that it is blown?
Mar 27, 2008 | Bose Wave Radio
Open Questions:
Pioneer DVR-220 DVD Recorder Logo
377 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
