Question about Dishwashers
Nothing lights up on the control panel, you can't turn it on.
    Genius:
  • 1,121 Answers
Check for fuses if electronic models is on principal board, if older models is located on mains input cable
Posted on Jun 06, 2010
When pluggged in, all lights behind the buttons on control touch pad panel light up, then go out. When the 'on' button is pushed, nothing happens. Can you tell me what the problem is? Thanx
First thing to try is turning off the power to the machine for a minute and then turn it back on, if that does not fix it then electronics have a brain problem. I have noticed that appliances with electronic panel controls are having many problems, my washing machine electronic control panel is bonkers but never had problems with the old mechanical controls. In order to fix mine I would have to order the whole panel as you cannot replace parts, I'm sure you unit is the same.
Mar 12, 2018 | Frigidaire Heating & Cooling
Cant get tv to turn on
Try leaving it out of the power overnight. Also, check all the cable connections.
Apr 05, 2008 | Ultra LCD30-500 Television
Sparform hot tub blower won't turn off
When an appliance will not turn off, no matter what you press on the control panel, you have either a non responding (dead button) topside control panel, or your topside panel did receive the message to turn it off and the circuit board is not responding.
  • If you have some kind of indicator light when you press your Jet/pump button, if the topside panel is operational and does actually receive your request to either turn on or off an appliance, an indicator will appear - either a light or icon.
    • If one does appear when button pressed, then dis-appears when pressed, that means your panel is good - as it is responding to the pressing of the associated button.
      • Bad circuit board
    • If nothing appears when you press the button, no lights or icons - indication of topside receiving your request, then you you have a dead button.
      • Bad Topside Control Panel
May 18, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hot tub makes a humming sound when you turn on the jets
Blower motor went out and blew fuse. You will have to replace the blower motor.
Apr 30, 2014 | Holmes Products HM495-UC Humidifier
Nothing lights up on panel
Always check your circuit breaker 1st to see if it is tripped.If that is ok turn it back off and check the household electrical connection to the dishwasher. This can be found by removing the kickplate below the door. The junction box is usually located in the lower right front corner. Check the wire nuts for a loose or burnt connections. If that is ok your most likely cause is the main control which is located in the control panel.
Dec 09, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Control panel light does not come on, light in freezer and refrigerator does not come on. Tried to run self test unable to get buttons on control panel to turn on. Tried alarm button. Also, no ice,...
Does ANYTHING work? Sure it's plugged in, breaker not tripped and GFI plug not tripped?
Plug something else into the outlet to confirm that it works.
Unplug from wall for 30 minutes to reset Bosch to defaults.
Still malfunctioning? Main control board is faulty.
Jan 05, 2018 | Bosch B22CS80SNS (220 cu ft) Side by Side...
Can't make copies
I had the same problem just yesterday. Turn off the printer for 10 seconds. Then turn back on. Turn back off again and unplug from the electrical outlet. Open the control panel and tilt it toward you. Close the control panel, plug machine back into the outlet and turn back on. I did this and it solved my problem.
Sep 10, 2008 | HP Laserjet M1319F Laser Multifunction...
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
