Question about AmcorAire UCHW-H18AF2 Split System Air Conditioner
Not blowing cold air
One line freezing up
    Scholar:
  • 45 Answers
If one line is freezing up with ice accumilation on it, the unit is low on freon. You may want to take the unit to your local appliance repair shop and have it looked at. I would request a quote for the repair before the work is done. Most of the time it is cheaper to buy a new unit than it is to pay the labor for repair.
Posted on Jun 07, 2010
Samsung RS2630sh. Drain line Freezes shut. Water drains to bottom of freezer and freezes there. Cooling coils are not collecting ice. Drain line has been cleaned. Why does it keep freezing shut?
If water still collecting and freezing at freezer bottom then drain line is not cleared and still obstructing the normal flow of water downward.
Aug 22, 2017 | Samsung Refrigerators
Water line freezing in door of GSL22JFXJLB Side by Side
the problem is the line is freezing up due to obstruction or blockage. which causes the water to back up and freeze, I have used a blow dryer, hot water, and a soft type long tiny tube or cord like material and even a coat hanger but be very careful, to get inside the line and unplug the obstruction or if u can remove the whole line and replace it? but may be very difficult. why was it pluged? some times pc's of plastic bags, old food particles, etc get into the line, doesnt take much
Mar 11, 2015 | GE Refrigerators
Bottle freeze
the pull on the bottle makes it freeze the lpg has to bubble to make gas if the line off the bottel is too small and the heater draw is large the the bottle will freeze, so bigger tank and bigger draw off line .
Mar 14, 2013 | All-Pro Propane Garage Shop Heaters - All...
My car taking longer than usual to start when cold and hot can u help me solve this problem
try some gas line anti freeze. it is not rerular anti freeze . it is just for the gas line it will say gas line anti freeze
Dec 02, 2012 | Volkswagen Cars & Trucks
My goodman unit is freezing up. It is frozen from the line running out of my house than if u look down into unit, the freeze continues inside
Hello, the suction line will freeze either due to low airflow such as dirty air filter, blower wheel, evaporator coil or a weak blower motor. Also, a low refrigerant charge can cause the suction line to freeze up.
Jul 16, 2012 | Goodman Heating & Cooling
Can you wrap tape around pipes
Yes, you can use heat tape on pipes UNLESS they are plastic or PEX. Copper lines - no problem.Heat tape is used to keep lines from freezing, and generally they do a good job at it, IF you get it wrapped around the part that usually freezes. BUT please understand the design purpose of heat tape before using! For example: My kitchen has an overhang that extends about four heet from the foundation that the water lines run through. In -30 F weather, my water lines will freeze up. I initially wrapped heat tape on the lines below the sink and still had freeze up. So I relocated the heat tape to the crawl space and wrapped the pipe as close to the foundation as I could. That solved the problem.
Nov 29, 2011 | Easy Heat Water Pipe Heating Cable
Freezing discharge line
The only way that a discharge line can freeze is if there is a restriction in it.
Are you sure it's the discharge and not the suction line?
Nov 22, 2009 | Carrier Heating & Cooling
Ds freezes
probly broke it
Jul 20, 2009 | Nintendo DS Lite Console
Game screen freezes and there are white vertical lines on the tv
i dnt know about the vertical line but i had the same problemand i solved this by taking it to my nearest computer shop its as simple as that
Apr 14, 2009 | Microsoft Xbox 360 Console
AmcorAire  UCHW-H18AF2 Split System Air Conditioner Logo
55 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
