Question about Craftsman 48" Cut Riding Lawn Mower Deck Belt 174368
LAWN MOWER WILL START , PTO WILL INGAGE, BUT WHEN PUT INTO GEAR MOWER WILL NOT MOVE FOWARD OR REVERSE WHEN LET OFF BREAK / CLUTCH ?
    Problem Solver:
  • 18 Answers
Check your drive belt
Posted on Jun 06, 2010
I have a LT1042, cub cadet. PTO clutch burnt up. I replaced it and the solenoid, fuse, and relay. Thinking that when PTO clutch burnt out that something else like a wire or sensor went out also.
Check all the safety switches u have a bad one look under the seat first that one is a common problem so I take it your PTO won't engage I bet your old PTO is still good the safety junk they put on these mowers fails a lot causing problems running your mower also look under the back side by the tire there is another safety switch that gets corroded that's switch is the one that will not let you mow in reverse if you want to bypass it u can just put the wires together then beware your mower will work in reverse also I hope this helps you have a great day Regards Chris
Aug 03, 2016 | Cub Cadet Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Were is the safety switch for the pto on craftsman riding lawn mower
well there's three, there's the seat switch which can be found under the seat of course, there's the reverse switch which will not let you cut in reverse (just unplug it to be able to cut in reverse it you wanted but be careful of the little ones) which is usually near the gear shifter and then there's the break switch located under the mower (look along the break arm just follow the break under the mower and then you'll see a bracket that's flat and when the breaks pushed down the flat piece hit the button switch... why are you concerned? did it stop working here's a tip that most shops wont tell you just replace the main pto button first its cheap and 60% of the time its the main cause of the pto not working, but they wont hesitate to tell you that you need a 400.00 or so new pto. hope this helps
May 16, 2015 | Craftsman Garden
How do I check the PTO switch on my RTZ22 mower?
Hopefully you put back the stabilizer for the clutch assy. If not then it spun the first time you you crank the mower engine and destroy it wiring connections.
If this didn't with the mower not run but the ignition in the on position disconnect the connector at PTO clutch. Now switch on the PTO switch and using a voltmeter (DVM) check for the battery voltage across the two wire at the connector. If voltage is there then the PTO clutch is bad. But if the voltage isn't present then either you have bad PTO or ignition switch or have wiring problem.
Mar 31, 2015 | Garden
John deere stx46 won't move in forward or reverse
There is a handle on the rear of mower make sure it is not in the free wheel position. If so push it in and it should move. If not seek out an authorized dealer to test your tranny. Also check that your belt didn\'t break
Aug 03, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
I WAS RIDING MY MOWER, WHEN I DECIDED TO CUT SOME GRASS, I STOPPED THE MOWER, PUSHED IN THE CLUTCH, ENGAGED THE BLADES, THE BLADES STARTED MOVING, I THEN PUT THE MOWER IN FOWARD LET OFF THE CLUTCH AND...
2 things, one, the belt jumped track, broke, or melted in place, 2, the hydrostatic ****** is out of oil, you didn't say if it was hydro or not. I doubt that the gear box has gone bad, but I would put more blame on a belt or pulley. Check it out. Hope this helps.
Mar 17, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
MY PTO CLUTCH IS SHOT BUT CAN I START MY MOWER WITH OUT IT WIRED UP
If by shot you mean it won't engage, yes you can start the mower. If you mean the anti rotation lugs are broken or the bearing has collapsed then no I wouldn't. Hope this helps, regards Phil.
May 22, 2011 | Cub Cadet Lawn Mower Electric PTO Clutch...
The mower turns on fine but when i engage the pto to start mowing it doesn't work and shuts off and blows the fuse
could have bad pyo switch or pto clutch.make sure every thing turns freely,blades and pullys then unplug clutch and try to enguage if does not blow fuse check clutch with meter. put meter on ohms probe one terminal and other on ground via clutch housing should not have continuety check other terminal to ground.voltage goes in one term and out the other like litebulb if potting (insulator) in clutch is melted wire inside will short on housing.hope this helps
Aug 14, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 48" Cut Riding Lawn Mower Deck Belt 174368 Logo
333 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
