How do i change an ink cartridge on a HP PSC 1510 printer
  • clairm May 23, 2008
    Clear and excellent advice. However, my printer did not automatically align the page. I did click on the Align button in the dialogue box. I checked the cartridges. I changed the paper. I tried to Align from the HP Director.
    Could the problem be that I have one new cartridge (black which I only use) and a color cartridge - perhaps empty - as I don't print in color.
    The question is - how do I troubleshoot and get the print to Align so the green power button goes off.
    Thanks,
    Clair M
  • 123 Answers
To replace the print cartridges
1. Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you lift the print-carriage access
door to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely on the right side when you try to remove
them.
2. Make sure the paper tray is down and there is letter or A4 unused plain white
paper loaded in the paper tray.
3. Open the print-carriage access door by lowering the door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then, using your thumb, lightly press down on a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
5. Pull the print cartridge toward you out of its slot.in-One
6. If you are removing the black print cartridge in order to install the photo print
cartridge, store the black print cartridge in the print cartridge protector.
7. Remove the new print cartridge from its packaging and, being careful to touch
only the black plastic, gently remove the plastic tape by using the pink pull tab.
8. Slide the new print cartridge forward at a slight upward angle into the empty slot.
Using your index finger, push the print cartridge forward until it clicks into place.
If the print cartridge you are installing has a white triangle on its label, slide the
print cartridge into the slot on the left. The label for the slot is green with a solid
white triangle.
If the print cartridge you are installing has a white square or a white pentagon on
its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon.your HP All-in-One
9. Close the print-carriage access door.
If you are installing a new print cartridge, the HP All-in-One begins to print a print cartridge alignment sheet.
10. Load the print cartridge alignment sheet on the right front corner of the glass with the top of the page to the right.
11. Press the Start Scan button.
The HP All-in-One aligns the print cartridges.
Good Luck.
Posted on Apr 10, 2008
What is the model of inkjet cartridge? Is it 0I-HP C9362(92)? coz i cant install in the ink, thx for reply!
Your printer uses the following ink cartridges:
  • HP 92 Black Ink Cartridge (HP part: C9362WN#140)
  • HP 93 Tricolor Ink Cartridge (HP part: C9361WN#14
  • dentifier"><span class="type">SKU</span> <span class="value">C9361WN#140</span></span>HP 99 Photo Ink Cartridge<span class="identifier"><span class="type">SKU</span> <span class="value">C9369WN</span></span> (HP part: C9369WN)
Jun 13, 2011 | HP PSC 1510 All-In-One InkJet Printer
Hello, My HP PSC 1510 doesnt works because is written incopatible cartridge. I tried to clean contacts and so on but it still doesnt work. what to do?
Incompatible cartridge shows that it believes that the ink cartridge installed in not compatible with this printer. It means that the printer can't use the cartridge that is installed. You need to return the cartridge and get the one that is made for your exact printer.
Take Care!
damnor01
Apr 18, 2011 | HP PSC 1510 All-In-One InkJet Printer
How to change ink cartridge on hp psc 1510
Hi, Please check this link: http://h10032.www1.hp.com/ctg/Manual/c00366227.pdf
Refer to pages 43-48 (printed number on the page or pages 46-51 in the PDF page guide)
Hope this works for you.
Cheers, Ed
Nov 25, 2009 | HP PSC 1510 All-In-One InkJet Printer
Compatible cartridge for HP 1513 used in INDIA having 136 & 132
HP printers supplier, can arrange or supply in Hyderabad India,
the hp printer PSC-1513 catridge (color)136 and catridge 132(Black)
or advice us, where could we get said catridges. Thanks
Sep 03, 2009 | HP PSC 1510 All-In-One InkJet Printer
My HP PSC 1510 will not take refill cartridges, - B/w and Color lights flashing
the cartridges are damage or not the right ones for your printer. first make sure you clean the cartridges before installing cos ink on the cartridge (panel) can stop the printer from detecting it.
Jul 01, 2009 | HP PSC 1510 All-In-One InkJet Printer
My 1510 is printing all black pages, now I'm out
Have you checked the printing preferences>color tab>greyscale>black print cartridge only option is not on?
Apr 02, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP1510 How to change out ink cartridgemarieconnor@live.ca
there is pull down face just above the paper tray, put you finger in the slot and pull it down you'll see the ink cartridges on the right.
Jan 28, 2009 | HP PSC 1510 All-In-One InkJet Printer
Ink levels
Open the printer preferences, click on the services button, locate "Ink Levels" and voila!
Mar 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
409 people viewed this question
k24674
jasbo
jasbo
