Question about Logitech AudioStation High-PerDocking Station formance Stereo System for Apple iPod - 970217-0403 (097855040244)
Hi my power supply is broken - no help from logitech in Australia - they've messed me around for six months plus! Do you know where I can get a replacement? If not, do you know where I can get a circuit diagram ( DH Mesa 24 B1) - there are several burnt components - at least two resistors and a fuse, and maybe some micro components - hard to tell the values as they are fried. Any help appreciated. thanks
4 Suggested Answers
  • 3 Answers
SOURCE: Logitech Z-680
I bought this system a while back and it started popping the speakers...
Come to find out the main volume controller crapped out I was able to get logitech to send me a new system and had it for about 2 years then the second main controller started doing the same thing then stopped working...
Will never buy a logitech speaker system again.
Posted on Jul 07, 2008
  • 87 Answers
SOURCE: Logitech X-530 5.1 speaker set blows internal fuse
Thats because its a 5amp 250Volts. You must have an older model and the beefed up the fuse later in production. mine just blew, unsoldered and about to replace. It states LF.T5AL250V. Hope that helps everyone. Takes about ten minutes to unscrew a good 20 screws, most of them are bolts and have nuts on the back so be prepared to have a pair of pliers handy, takes a 5 dollar solder gun from walmart to heat up the solder in the two points that are holding the fuse, once solder turns to liquid pull one side out, do the same to the other side to free the fuse. Fuse is in some kind of hold that i nearly impossible to remove (if you removed it then your in good shape, replace and solder in again) if you didnt remove it then head to home depot and pick up a small fuse holder and solder the leads in with just cheap solder from walmart. Be sure not to drip any solder over anything else on the board. Overall pretty easy fix.
Posted on Jun 03, 2009
  • 13433 Answers
SOURCE: power supply 4 logitech momo wheel force
powersupply for logitech momo. is
Logitech Ac adapter P/N: 190211-a110 Model: ADP-18LB
Input Ac 200-240
output: 24v --- 0.75A
Note this is the europe version.
Posted on Jul 26, 2009
Hi I've had my HP laptop from Telus for approx six
Dead battery? If it's six months old return it A.S.A.P.
Jan 18, 2013 | Computers & Internet
Broke fins/tumblers
This is an easy fix. You need to pop the top of the dryer up to do so. Depending on the model you may have to take the front off (older models), or just locate the clips located on the left and right side under the lid, and with a flat head screw driver push them in and lift up. (newer models). After you have the top up, located the baffle thats broken and install. Keep in mind that if the baffle is loose its more than like the hole where the screw goes is stripped and the whole baffle should be changed.
May 29, 2012 | Maytag MDE5500AYW Electric Dryer
My iphone4 will no longer play music in my s715i. I have 2 gigaware boxes it will still play in just not the logitech. Says not supported. Played great for first six months, I know it is an iphone...
Hi harkirj,
There's an ongoing compatibility issue with Logitech s715i and iphone/ipod. If you're using iphone 4 with iOS 4.3 you will be encountering no sound or unit won't play at all. It only works for iOS 4.2. You can use a 3.5 mm jack, connect it to the top of the iphone to the back of the player and it will work. However, you will lose all functionality of the remote, battery etc.
Hope it helps.
Thank you for using FixYa.
Jul 10, 2011 | Logitech Rechargeable Speaker S315i...
Power supply different voltage supply will it work in Australia
Unless the power supply is a multi-system* type, the unit will not work in Australia without major modifications to suit the mains voltage. The differences between USA and Australian voltages are significant. We use a higher voltage rating for appliances than America does, and appliances made for Australia operate at around 220-250V AC.
In order for it to function correctly and safely in Australia, the power supply would need major modification, which can prove expensive, and often impractical.
Mar 02, 2011 | Magnavox MDR513H/F7 Player
Hi. I recently moved house, as a result, my Logitech EX100 wireless keyboard sat in a box, unused for about a month. I unboxed it and set up my PC once we'd moved house, but I couldn't get the keyboard...
When batteries leak, they usuallly rot out the connectors and anything in the local. Your warranty may have been voided with that so don't be too hard on yourself because you had a crack at sorting it out.
Besides, you've now got a trendy doorstop.
May 11, 2010 | Logitech EX100 967499-0403 Keyboard
My daughter has acquired a Mustek 600 III EP Plus scanner, unfortunately without a power supply. I know it is 15 volts 1 amp dc, but is it +ve or -ve tip?
Mustek 600 III EP Plus scanner, Power adapter type output +15VDC/1A Positive Polarity (positive inside and negative outside).
Sep 25, 2009 | Mustek TwainScan 600 III EP Plus Flatbed...
Yeah i´ve got the same problem
Hi, Please reset your squeezebox, to do so, unplug the power supply from the SQBx and push the button 1. Keep pushin 1 and replug the power supply, do not release one untill you see " Factory reset " Should fix your issue. Thanks and have a nice day J -
Jul 30, 2009 | Logitech Squeezebox Duet
Need to know where to purchase simpletech 963000-41001-011 ac adaptor
Often you can find power supplies on eBay but I could not see anything that matched your equipment but you may want to try a search again another time.
I'm not sure what part of the world you are in but if you take your broken power supply into an electronics store like Tandy, Radio Shack. I'm in Australia and **** Smith or Jaycar should stock these unless yours is very unusual.
You need to match the Input voltage for your country (if ordering online) and the output voltage for your device. Plus the Amps required for your device. This is normally written on both the adapter and the device.
If you are lucky you will be able to find one with the right shaped plug to fit your device. If not you will need a couple of connectors and you can use the plug off your old power supply and just join them up. Don't forget to check the polarity ( + and - ) if you get them around the wrong way you will likely break the drive. There are always small multi lingual symbols that describe which way around the + and the minus goes.
Hope this helps and Good luck
Jul 16, 2009 | SimpleTech (sti-u2f36/250) 250 GB Hard...
Windows Vista
http://www.softwarepatch.com/utilities/logitech-webcam-driver-quickcam.html
Try these, it works for me on Ultimate after a bit of compatibility tweaking (a lot of it on my account as I messed up the install and had to clean up the mess)
Try it out.
Oct 25, 2007 | Logitech Quickcam Zoom 5 Pack Webcam
Dead Power Supply
Call 888-257-8899 $69.95 plus shipping
Feb 19, 2007 | Protron PLTV-32 Television
Logitech AudioStation High-PerDocking Station formance Stereo System for Apple iPod - 970217-0403 (097855040244) Logo
62 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
