Question about Dell 924 All-in-One InkJet Printer
Hoe to install cannon ip 1900 to computer
How do i install cannon printer to my home pc computer so i can print off computer
    Problem Solver:
  • 4 Answers
Go to the Wbsite where your Printers Manufacturer and download and install the drivers for it. Follow the instructions on how to install the drivers. Some Driver rrquire that the Printer NOT be connected and some need to be when installing th edrivers. Hope this helps
Posted on Jun 06, 2010
Fix code error canon printer ip 1900 series
Kindly provide more error details on your iP1900 series printer. Any error code? How many times light blinking?
Jun 27, 2013 | Cannon Office Equipment & Supplies
I have just purchased a Dell laptop with Windows 7 home premium installed. I have a Cannon PIXMA MP495 printer, what do I need to do to operate thist printer wirelessly?
If you have a wireless router with a wireless network then -
Configure the IP address your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but at a higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Oct 28, 2012 | Dell Computers & Internet
"An ink cartidge is not
clean & align the cartridge.
Feb 12, 2011 | Office Equipment & Supplies
My Canon iP 1900 series always error 5100. can u help me???.........thanks before...
hi erichhafivx,i am happy to help you
Follow this steps
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
I think waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width) The unit is not homing, check for obstructions.
Good Luck
Jan 12, 2011 | Computers & Internet
My IP 5000 Cannon printer says I have a paper jam but
Under the circumstances go to control and click on printer. Clear all the printing jobs. Switch off the printer and the computer. Wait for sometime and restart the computer and the printer. This should clear your problem.
Dec 20, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Remote printing was working and then it stopped.
If this is a network printer. You can reinstall the drivers that came with the printer as a local printer, then go into control panel open the 'printers and faxes' right click on the printer that you reinstalled, 'properties' go to ports tab, select add port, -> 'standard tcp/ip port' -> 'new port' -> next -> put in the ip address for the printer, it will be the scheme of you subnet for example if your ip address for your computer is set to 192.168.1.1 you would use the ip address for the printer port of 192.168.1.2. after that is done press next-> after that you will be set as a network printer. Try to print a test page.
If this does not work, you can install the printer locally on a separte computer, such as your home pc, and make the printer a share. Then simply add the share printer on your laptop. for example; after you install the printer on your home pc, go under control panel, -> right click the printer -> sharing-> enable printer sharing... -> Next -> You will be prompted on the sharing tab-> select 'share this printer' -> type a share name, such as 'Lexmark2' -> click ok. at this point you will see a hand under the printer, showing it is shared.
Note: you will need to get the computer name of the pc that the printer is locally installed, your home pc. for this example lets name the pc 'home' you can find the name of your pc by right clicking on my computer and select properties. go to the computer name tab.
also remember we named the printer share 'lexmark2'
now go to your labtop, go to the control panel and select 'printers and faxes' select add a printer on the right column. a windows will pop up, click next -> select 'A network printer, or printer.....' click on the radio buttion that reads 'Connect to this printer (or to browse.....' should be the 2nd option. this is where you are going to use the computer name and printer name.
put in
\homelexmark2
click next -> then finish
print a test page, from your labtop.
If you need further help please contact me.
keiffertech@techie.com
Dont forget to vote!
Sep 06, 2009 | IBM ThinkPad T61 Notebook
I cannot get my Cannon IR C3100N printer to print from my computer, it turns on but will not Print,Scan ect. Thanks John
you need to make sure the ip address is set correctly on the copier and make sure you have the correct driver installed on your computer
Apr 12, 2009 | Canon Office Equipment & Supplies
Canon L:BP3500 with Vista business
Here are solutions to some common problems with Vista that you might encounter while trying to add or use network printers,
If you have used the printer before without problems, try these options:
• Make sure that the network is working and that your computer is properly connected to the network. For more information, see the following Help topics:
View the status of your home network
Identify and resolve home network problems
Troubleshoot network and Internet connection problems
• Check the status of the printer in the print queue, or go to the printer to make sure that is it powered on and ready to use.
• If the printer is plugged in to another computer and shared on the network, make sure that computer is turned on. If it is turned on and the problem persists, contact the computer owner to make sure that the computer is connected to the network.
• If you are trying to print to a printer that you added using a TCP/IP address instead of a printer name, make sure that your computer is connected to the Internet or the network where the printer is installed. If you recently experienced a power outage, the printer TCP/IP address might have changed. The new address will not work with the printer port that you used to connect the printer to your computer. Try to add the printer again. For more information, see Add or remove a printer.
If you recently installed a new version of Windows, changed the printer driver software, or are trying to print to the printer for the first time, you might need to install printer drivers that are compatible with the version of Windows that you're running. If you are trying to use a printer that is plugged in to another computer and shared on the network, make sure that a driver for your version of Windows is installed on the other computer.
Hope this helps
Dec 28, 2007 | Office Equipment & Supplies
Printer will not network
Hi Stukie, Something you can try. Install the downloaded "newest" driver in all you PCs and laptops even if they cannot see or share with the PC print server. If you can successfully install on each PC, then you try changing the port setting of the printer on each PC. Go to Start, Printers and Faxes, Right click on the HP LaserJet 1000 (assuming you were able to install on every PC), click on Properties, click on Ports Tab, Click on Add Port, Double click Standard TCP/IP Port. A new window will pop up > Add Standard TCP/IP Printer Port Wizard, in the IP Address, type in the IP add of the PC where the printer is installed, Port Name can be any name but try the Shared Name of the Printer, Next and follow all other instructions. Hope this works for you and pls post again how things turn up. Kind regards.
May 22, 2007 | HP LaserJet 1000 Printer
Dell 924 All-in-One InkJet Printer Logo
59 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
