Question about Ruud UBHC Air Conditioner
A/C will not shut off - Ruud UBHC Air Conditioner
    President:
  • 1,515 Answers
Hi, the photo is showing a split system, indoor unit and outdoor unit. Is it just the blower fan inside that keeps running, or the entire a/c keeps going? Lets say its everything. I would start at the thermostat and remove the cover to expose the control wires. Find the R terminal,Red wire and use a small screw driver to remove it from the terminal. If the unit shuts off, the thermostat contacts are faulty and you will need to replace the stat. Even though its only low voltage, 24 volts, I would shut off power when you take the wire off. If your stat is not a digital, you will need to remove cover and lossen several screws to remove the stat to get to the subbase and wires. On a digital you don't have to. After removing wire, turn on power to see what happens. If it keeps going, you have a thermostat wiring problem either at the indoor unit where the thermostat wires come in and connect or at the outdoor unit where they connect touching together somewhere. The red and green or red and yellow conductor wires have a bare spot and are calling for cooling all the time. You will have to look for this, it can be very difficult to find unless you can ohm out the wires. If its only the indoor fan running and not the outdoor unit, it still could be the stat, or you have a fan relay that is stuck. If you remove the panel on the indoor unit and look at the wiring diagram, don't let it confuse you, look for this, IDF and follow the wire or wire to FR fan relay. Depending on what type, you can try tapping on it with the but of the screw driver carfully, to see if that may shut it off. If not you will need to go to a a/c parts house or a appliance parts house to find one. Draw a good diagram so you know how to hook the wires back up, or you can get into more of a bind. Its worth doing this then trying to remember. Do these things and keep me posted on this. By removing the R, red wire at the stat will kill power to the fan if the stat is the problem, so you don't have to remove the G, green wire for fan, only the red. I will wait to hear back from you.
Best of luck,
Shastalaker7
Posted on Jun 06, 2010
Which parts should be changed to solve the problem not to automatically shuts down
It depends on why it is shutting down. Is it overheating? Is it full of dust or pet hair? Does it shut down normally showing you a shut down screen or does it merely turn off. If it turns off, then I would check fans and heat pipes. IF it shuts down with a shut down screen you would want to check your windows install.
Oct 16, 2016 | Computers & Internet
Just replaced the circuit board after a technician told me that was the problem. White Rodgers 50A56-956. Getting the same result as the old board: clicks on, shuts off
White Rodgers relay clicks shuts off Surveillance Cameras ...
www.fixya.com > ... > Tags > relay clicks shuts off > Surveillance Cameras
White Rodgers surveillance cameras relay clicks shuts off related questions and answers. Ask your White Rodgers questions. Get free help from surveillance ...
White Rodgers car will start up but shuts off Surveillance ...
www.fixya.com > ... > car will start up but shuts off > Surveillance Cameras
White Rodgers surveillance cameras car will start up but shuts off related ...Thermostat works, clicks when turn on heat, shows Stage 1 on display (hooked up .
relay clicks shuts off Surveillance Cameras Questions ...
www.fixya.com > Forum > Tags > relay clicks shuts off
Surveillance Cameras relay clicks shuts off questions and answers. Ask your relayclicks shuts ... I have a white-Rodgers 1F86-244 thermostat. When I ... a new ...
Jan 16, 2016 | White Rodgers Home Security
Pull the keys radio never shuts off, I replace the fuse because it was burnt out.
radio will not shut off when car turned off - Car Forums and ...
www.automotiveforums.com > ... > Chevrolet > Cavalier
I have this anyoing problem..when i pull the key out of the ignition the radio ... They could not wire it so that when you opened the door, it would shut off. .... I NEVER had to do anything with the airbag wires or shut the airbag off or anything!
07 Silverado Will Not Shut Off With Key Removed - 1999-2006 & 2007 ...
www.gm-trucks.com/.../115642-07-silverado-will-not-shut-off-with-key...
Jun 27, 2010 - 14 posts - ‎8 authors
The only way I can shut it off is to pull the fue... ... It runs perfect as if I never shut itoff. It is not dieseling it runs like the key is on. The complete vehicle shuts down like it is off ie all dash lights, radio, go of and it will not allow the ...
VW Jetta MKIV/MK4: Stereo doesn't shut off with car 'Volksw
Dec 30, 2015 | Cars & Trucks
I am having a problem with shut down the computer.After shut down command it displays windows will shutting down and hangs but will not shut down i need to press the power button to shut down(My computer...
Something is not closing on exit. Try running in safe mode, then shut down. If it shuts down then something is loading and present in the taskbar which isnt closing down.
Dec 19, 2010 | Computers & Internet
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
#1:
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
#2:
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Nov 08, 2009 | Toshiba Satellite A135-S2386 Notebook
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
Aug 07, 2009 | Acer Computers & Internet
Television shuts itself off
i had the same problem with my set shutting off and was told it may be the ballast so i changed that but it still would start up and shut down after a few mins, then i was asked if the bulb had been changed and i had not, so i did change the bulb and have not had it shut down yet. :) (so try a new bulb)
Jun 01, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a 96 cadillac deville and my interor lights wont shut off
timer is bad that shuts them off after u open and shut a door
should go off when u get in and start up vehicle
Feb 06, 2009 | 1996 Cadillac DeVille
Ruud UBHC Air Conditioner Logo
153 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
